For turbo guys with upgraded Clutch
One quick question, is the aftermarket clutch (ACT etc) smaller than the stock clutch on your car? Can some get me the size (diameter) of the clutch plate?
Thanks
Thanks
not sure of the size but even 6th clutches work on our car. I bought the ACT Stage 2 extreme, with a pro-lite flywheel. Love the setup...
A clutch from 6th Gen does not fit my car. Therefore I took some measurements and if someone can help me identify which Honda Clutch plate this is according to American Spec then I can order a kit from ACT or some other company.
The Clutch Plate measures as follows (approx):
Overall Diameter = 8.4 inches
Thickness = 0.25 inches
Length of the leather type portion (from inner circle to outer circle) = 1.25 inches
The inner most hole, where it bolts on or fits the transmission, is the same as the clutch of 6th Gen Vtec models.
I know all above is not a very good explanation but I hope someone can understand what I am talking about and can help me.
Thanks!
Thanks!
Let me know if you need an ACT, Clutchmasters, Exedy. I got em all and they are on the shelf www.truehonda.com
