Oil Feed Flange
Oil Feed Flange
Does anyone know where I can buy an oil feed flange for a T3/T4? I just bought my feed/ return fittings and lines and when I went to mock everything up, I noticed that the feed port on my turbo isn't threaded. The only flange I have found is at ATPturbo.com. That flange would work fine but it is an 8mm thread and my feed line is 1/8" NPT. So if anyone knows where I can get a
1/8 NPT oil feed flange for a T3/T4, I'd really appreciate the help. Thanks
SRT-4 owner with 2MCHPSI
check stan out at www.fast-turbo.com
he should be able to help you out...if you dont see it on his site, give him a call
I'm going to change my SF kit oil feed lines to -3AN, and I was also wondering where to get the adaptors and crap. I was looking around mcmaster.com, but could only find a 1/8" BSPT Male to NPT Female adaptor and a 1/8" NPT Male Female Female T fitting. I'd like to get steel parts, especially for the T fitting, to ensure nothing breaks.
another option is a 1/8" Female Male Female T, which would have less chance of breaking because of less leverage.. I would imagine. question is, would the oem pressure sensor fit with it at that angle
edit: another question I hope someone has an answer for-- because the oil sender uses BSPT threads, wouldn't the stock pressure sensor use BSPT threads? seems like people just use the Female NPT T fitting anyway.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
fafa1234
Aug 8, 2015 06:42 PM
fecrni
Aug 8, 2015 06:15 PM
7thgensurvivor
Jul 27, 2015 08:23 PM
