Alcohol injection?
Old May 30, 2004
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
Alcohol injection?
okay I got my turbo installed today...I have a ? about the alcohol injection...at what psi does it suppose to shoot in at...my comes on at 4.5psi but I heard its supposed to shoot in at 7psi or so...how do I adjust it...
Old May 30, 2004
fuchs's Avatar
fuchs is an unknown quantity at this point
Congrats man, post up some pics already. Anyway, on the back of the pressure switch there is a little rubber seal. Take it off and there is an allen screw there. That is your adjustment screw. You just have to play with it to get it right. Also...Did you get an oil restrictor with the kit?
Old May 31, 2004
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
how do you like being boosted?
how did the install go?
Old May 31, 2004
JetBlu01's Avatar
New Member
install went SMOOTH...really it did...well I had some good experienced guys doing most of the work while I learned and played TB and helper lol....anyways...when I get her cleaned up... I will post up pics...the plan is to put the wideband on there tomorrow...will let u know how it goes....5psi feels good and 8psi feels good so far...I've only done 8psi once and I ride with my boost controller off the rest of the time and just go off the acuator....boostin' is ADDICTIVE..even my lil' water sprinkler BOV sounds good to me (b/c its new to me)
sweet...will adjust the alcohol tomorrow...
WHATS BEST ALCOHOL WATER MIXTURE TO USE...WHAT KIND OF ALCOHOL AND HOW MUCH thanx...
Old May 31, 2004
fuchs's Avatar
I use 50/50 distilled water and denatured alcohol. We have 55 gal. drums just sitting around. The army IS good for some things
Old May 31, 2004
civic01vtec's Avatar
hmm.......how do you adjust it to know what psi it is activated ?????
anywayz, i found a place that sells racing alcohol, so i run it straight. Running it straight will give you more power but will cause hot spots. The water is used to cool the intake temp. If i go on semi-long trips, i'll throw some water in there then and maybe some ice.
Old May 31, 2004
JetBlu01's Avatar
New Member
where it shoots in your intake, unhook it then get someone to spool up the turbo for u and watch the boost level to see at what psi it shoots out the alcohol....really I'm shooting a 4.2psi....I'm gonna adjust it today...hopefully put the wideband on it and see how it runs then....so far I'm satisfied
thanx fuchs...yeah right now I got a bottle of denatured alcohol and tap water (50/50) in it now...I need to refill
Old May 31, 2004
6thGenHatcher's Avatar
6thGenHatcher is an unknown quantity at this point
Use pure M-1 racing methanol. Also run an lcd to your alch pump. Then you will see right when it activates.
Good luck.
Old May 31, 2004
JetBlu01's Avatar
New Member
Good luck.
yeah we thought about that yesterday...good idea...I'll keep ya posted
Old May 31, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
Yes, Pics Pics Pics!!
Props on using a wideband, not alot of people use those. In the long run, the extra money will go a long way when you really want to tune your car.
Are you using PLX wideband? if not, which one?
Old May 31, 2004
JetBlu01's Avatar
New Member
I"m using the Tech Edge Wideband... at 5psi, I'm running 8.5 to 1 A/F and on 8.5psi, I spiked 12.0 then went down to 10.8 to 1 @ redline A/F so its running pretty safe...I'll post pics tomorrow when I clean her up
Old May 31, 2004
Good I'd like to see what it looks like, never heard of that brand, sounds good though buddy!!
YAY FOR PICS!
PROPS TO JETBLU! I'm adding you to my heros..
Old May 31, 2004
Good luck.
good idea, i am gonna have to look into that.
Old May 31, 2004
ImportRacer2123's Avatar
K20 Member
Damn alcohol injection seems like Nitrous. The reason im going the turbo route is because im sick of having to rely(sp?) on a bottle in my trunk to make me go faster.
Old May 31, 2004
ahhhh....... bout time you got converted
Old May 31, 2004
K20 Member
LMAO! True true now im in the Boosted Family...well not yet but soon.
Old Jun 1, 2004
fuchs's Avatar
To see where the alcohol comes on, just hook the hose back up to the washer sprayers and go for a ride. when the alcohol hits the windshield look at the boost gauge.
Old Jun 1, 2004
JetBlu01's Avatar
New Member
yeah that or either put your ignition on the ON position, get an air compressor and take off your air filter and pipe that goes to it...pressurize it (run air from the compressor into the piping) and have someone to push down on the gas till u see at what psi your alcohol injects at so u dont have alcohol on your windshield...lol....thanx to fuchs though for telling me how to adjust it...now I have mine set at 7psi instead of 4.2psi where it was originally set at....
Old Jun 1, 2004
K20 Member
Can someone takes pics of the alcohol injection? where is is located and where the box is? Thanks Alot.
Old Jun 1, 2004
K20 Member
Old Jun 1, 2004
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
i'd also like to see pics, of both the alc injection and the overall turbo kit installed, especially the FMU, throttle body, and oil lines to the turbo... those are the most confusing parts to me. i've been requesting pics for a long time and still no one comes forward all I'm waiting for now are the intercooler mounting rods and fuel hoses-- been waiting for 2 months
Old Jun 1, 2004
JetBlu01's Avatar
New Member
I'll take pics of my engine bay today
Old Jun 1, 2004
JetBlu01's Avatar
New Member
couple of shitty shots....I need to clean her up and give her a bath....and couple other modifications but I need to rest for now...lol
Old Jun 1, 2004
sorry, i don't have a digi, so i can't provide pics.........but if you need help when you install the kit, i will gladly help you out. Hit me up on AIM or u can PM me for my cell #.
Old Jun 1, 2004
civicskater's Avatar
Chicks dig my scent
i run a 50/50 mixture as well. I've only ran 9psi and i began spraying alc. at 6.5psi all the way through. ive had problems with leaning out about 5,500rpm though...but its not bad, just need to watch it
Old Jun 1, 2004
K20 Member
where is the alcohol injection can someone circle it?
Old Jun 1, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
It's off the back side of the charge pipe. You can barely see the injector and pressure sensor.
h4ldol
Apr 24, 2017 08:16 PM
RIPSAW
Aug 16, 2015 12:14 PM
15EXCoupe
Jul 30, 2015 12:59 PM
ak
Engine Swaps
29
Jun 18, 2003 07:15 PM
2k2civicballer
19
Apr 26, 2002 01:57 PM
