turbo for daily driving
Old May 29, 2004
acesfull's Avatar
acesfull is an unknown quantity at this point
hey got a question?
if i get a turbo kit and drive normally (as in not aggressive) will it still be alot of up keep! thing is i dont know alot about turbo's and this will be my first kit if i do get one. what you guys recommend!
Old May 29, 2004
dragoon's Avatar
more frequent maintenance is a must, and you'll have to check on things more often, but it should be just fine for daily driving
Old May 29, 2004
acesfull's Avatar
hey what kind of things will i be doing. i figured this will be the best way to learn about cars since i dont know much! what kind of regular checks will i be doing?
Old May 29, 2004
dragoon's Avatar
fluid changes, mostly.
you'll also want to check if any piping or hoses are getting blown loose, stuff like that. best advice is to read all the information that is already posted in this forum, there's a lot and should keep you busy for a few nights
Old May 30, 2004
civic01vtec's Avatar
yeah, what dragoon said.......check pipes, lines and you must change oil around 2,500 miles.
Also, if you drive like a normal person, your car won't be under much boost at all.......you are under boost when your car is under a load and you jump on the throttle.
Old May 30, 2004
VicCivic02's Avatar
VicCivic02 is an unknown quantity at this point
i have the kit and use it daily driving... have it set to 5psi.
but as you i drive "Normal" and dont beat on the car.
i change my oil every 1700-2000 miles, and every other week ill just check the pipes
make sure they are still tight.
as for hoses i just look make sure everything is looks okay.
Old May 30, 2004
acesfull's Avatar
whats that thing where u can change the psi setting while in your car?
Old May 30, 2004
VicCivic02's Avatar
you need an electric boost controller...
or you can get something like Hallman boost controller which is manual boost with an adaptor piece you can get to add in the cabin.
Old May 30, 2004
acesfull's Avatar
thanks everyone! looks like this will be one hell of an expierence!
Old May 30, 2004
Cocky's Avatar
Cocky guys kick ass!
damn.. 1700-2000 miles, check piping every other week.. maybe i don't want a turbo. well, time for lambo doors and Hayame Full Coilovers.
Xuhme
21
Aug 7, 2023 03:40 PM
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
Supramk3
May 11, 2015 07:55 PM
Supramk3
May 8, 2015 11:16 AM
smmahan
Apr 15, 2015 08:17 PM
