How to set the greddy profec b spec II
Old May 24, 2004
Samari's Avatar
I dont know how to set the low and high cuz it shows it in percent and I dont know what PSI i would be at. Can someone tell me there setting.
Old May 24, 2004
kikoman0's Avatar
kikoman0 is an unknown quantity at this point
search...i posted a thread about this earlier. It's a biatch to get to work. Seriously it's hella trial and error. Search and look for my thread...it's very informative.
Old May 24, 2004
Samari's Avatar
what are ur settings?
Old May 24, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Search Honda Tech. I helped someone tune theirs a few months back.
Old May 24, 2004
Samari's Avatar
can someone just tell me there setting.
Old May 25, 2004
kikoman0's Avatar
search for it man it's not that hard
Old May 25, 2004
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
Y CANT U GUYS JUST HELP HIM INSTEAD OF TELLING HIM TO SEARCH SEARCH SEARCH...either u do know or u dont...if u dont know off the top of your head then dont reply and I'm sure he will search once he sees there's no replies...some people
<--- has 56K and doesnt have time to be doing all that searching and shitt...
Old May 25, 2004
Havok2k1's Avatar
Wicked Pissah Admin
This is what kikoman is referring to....
http://www.7thgencivic.com/forums/sh...d.php?t=135264
Old May 25, 2004
Your Parts Guy
Ya but that isn't going to help. I don't think that you can control boost below what your wastegate spring is rated at with the Profec. I've tried everything and I still get spikes. Here's the basics:
The GAIN setting is used to control spiking. The first and third settings must be as close as possible to reduce spiking. The first setting is relative to the max psi your turbo can put out. Meaning 100% is MAX. Let's say you want to run 5 psi and your turbos max is 20 psi. Set the first setting to 25% and the third setting to 5 psi. If you want to run 10 psi set the first setting to 50% and the third setting to 10 psi.
Hope this helps.
Old May 25, 2004
andyman97's Avatar
Turbo Guru
Something I've found that makes a huge difference....
Once you start setting it, cycle from hi to lo or lo to hi. Make sure to do this everytime you start the car and once you get it set, the spikes will be gone. It made a huge difference with consistency on mine.
Old May 25, 2004
Your Parts Guy
Sounds like a bug to me.
Old May 25, 2004
kikoman0's Avatar
yeah i've also noticed that but I'd rather not cycle it like that. If you keep messing with it, you'll get consistent settings. Personally though I don't like this boost controller =\
Strycker
Aug 18, 2015 02:25 PM
Misfit2613
Jul 30, 2015 09:49 AM
cukaracha
30
Jul 26, 2015 12:01 PM
Jul 12, 2015 11:54 AM
