Turbo install HELP (fuel hose problem)
Old May 23, 2004
Samari's Avatar
Okay, ran into a problem with the install. Actually 2 problems.
1) Filled up oil and there seems to be a small leak in just one area of the oil pan. I dont know waht the deal is. Im thinking maybe we didnt put enough seal on it before we put it back on but maybe someone might know something. Also maybe we didnt clean the old seal off good enough before putting the pan and new seal back on. Can someone give me some info on this.
2) still messing with the fuel system. Just need to hook up 1 wire and other stuff. Im trying to find a install manual for the mf2 fuel system.
Please someone help me out.
New Problem
We check the fuel by turning the car on to where the fuel flows and 1 hose has a fuel leak and its not cut or anything. The clamp is on tight. I dont know, maybe a smaller clap or what?
Old May 23, 2004
Samari's Avatar
found something on the mf2.
this is for the yellow wire which ive been tyring to hook up so let me know if you can think of where to hook it up. it says:
"this cable goes to the ignition coil negative. RPM pulses are picked up via this cable. As this cable carries ignition coil switching pulses, do not run this cable near the original ecu cable loom as this might cause unnecessary interference. this calbe can also be used to pick up any RPM pulses generated by any ancillary device, ie: alternator, crank sensor, etc... if coil negitive is not available."
Old May 23, 2004
Samari's Avatar
bump
Old May 24, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
the yellow wire goes to the tach
Old May 24, 2004
Samari's Avatar
where is the wire for the tach located?
Old May 24, 2004
SODJAZERO's Avatar
http://www.7thgencivic.com/forums/sh...highlight=tach
CarStuff
Dec 6, 2020 12:52 PM
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
blacklud
Apr 13, 2015 06:15 PM
MooCoW
Nov 15, 2001 10:58 AM
Lightman
Nov 10, 2001 06:44 PM
