higher compression?
Old May 15, 2004
higher compression?
I was wondering what having higher compression would involve. The ported head I got is milled 1mm, so the compression is definately gonna be higher.
So what are some of the problems I would need to solve. Some things I thought of so far:
--need cam gear, because cam timing will be off
--higher octane gas?
--will regular plugs work, or do you need a hotter/colder plug?
Anything else I should be worried about please tell. Thanks.
Old May 17, 2004
tiredwolf's Avatar
tiredwolf is an unknown quantity at this point
i think your supposed to use colder plugs with nitrous and turbo and any other high horsepower engines...because i think they work better with more intake of air and fuel.
you will definately need higher octane gas, to keep the engine from knocking.
Old Mar 4, 2005
Does anyone else know? I'm thinking of switching to regular 87 instead of 89. What would I listen for or look at to make sure everything still runs okay? I think my compression is around 160-180psi instead of stock 130. Is that low enough to still run 87??
Old Mar 4, 2005
C2i0v0i1C's Avatar
SuperMODrizd
static = detonation
Old Mar 4, 2005
sw388integra's Avatar
are you using a stock head gasket? you should probably be putting higher octane in anyway. you can use 93 all the way to 11.8 to 1 comp.. But you're no where near that! if using 87, you should retard ur timing because of the knock sensor...but one question, WHY would you run low octane with higher compression?!?!? you spent all that money on that head and you want to put poo in it....
Old Mar 4, 2005
djmota's Avatar
just get the cam gear and adjust it. If you don't hear any clicking under acceleration 87 is ok for everyday. but run 89 or 91 to get some better performance.
Old Mar 4, 2005
Cool I'll stick with 89 then. The cam gear is on order (5 bolt this time), and will prolly be advancing the timing since milled head already retards it. It's all getting tuned soon tho. Thanks for the posts.
Old Mar 7, 2005
djmota's Avatar
I advanced my gear 2 degrees, reset my ecu and retuned my fuel. I noticed a difference.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
solarpunk70
Apr 12, 2016 11:43 AM
Bruce2
Sep 27, 2015 08:45 PM
NROD315
Sep 23, 2015 03:46 PM
NROD315
Sep 12, 2015 02:46 PM
