Alcohol thread: UPDATED
Old May 11, 2004
MadWheel's Avatar
Premium Boosted Member
I bought Isoprpyl as stafford reccommended. Cranked it up to 9.5 pounds and the car was REDICULOUSLY fast. But, at the top of third, it felt like I slammed the brakes.... So i let off, and the car was almost dead, backfired twice (really loud) and wouldn't idle right at all. It was fluctuating from 500rpms to 650 (hks turbo timer). I shut the car off for 15 minutes after I had pulled over. Started it up, ran fine. Drove it home. Took my mom's car out and bought a new set of Denso Ik20s. Went to go inspect everything, the old plugs were loose! and the 2 bolts that hold my rear section off had been blown back and the rear section was rattling, I had to replace the back two bolts.
I'm assuming the alcohol I bought caused this misfire. IT was running perfect at 7.5psi. The one time I had it at 9.5 it did that.
Also, the isopropyl was 70/30 (30% water). Any ideas or suggestions?
Thanks guys. If this thread get's good I'll make it a sticky for a while.
**UPDATE UPDATE UPDATE:**
Diagnosed the car. Turns out, it wasn't due to the isopropyl mixture, it was because of my lack of isopropyl. The switch that SF sent me stopped working while I was at 9.5psi!!!! My car severley misfired and wouldn't idle, but after a 15 minute break for the engine without running, she started back up. I bypassed the switch while the car was off and tapped the 2 leads together, electronics are fine. The switch just doesn't turn the pump on anymore. I guess the head gasket riceburner found is living up to it's word!
New question, where the hell can I find a new switch that would work? SF won't answer the phone and their voicemail is full...
Old May 11, 2004
MadWheel's Avatar
someone must have alcohol injection besides me!
Old May 11, 2004
RiceBuRNeR's Avatar
Turbo Member
try using denatured alcohol, it has a different octane rating.
Old May 11, 2004
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
I'm gonna go with 50/50 methanol once I get my kit on.
Old May 11, 2004
MadWheel's Avatar
Where can I buy that?
Old May 12, 2004
MadWheel's Avatar
anyone? i know there's tons of people out there that inject alcy... i just need some tips...
Old May 13, 2004
MadWheel's Avatar
bump, read first post and look for update
Old May 13, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Check that HG..... Knock at 10 pounds is a very bad thing... Especially when the car wouldn't run.... At least read the plugs....
Old May 13, 2004
MadWheel's Avatar
plugs are fine, i replaced them. car has been daily driven since the incident, and i raced the car at import wars 3 times after the alcy incident occured. no signs of any hg failure and i beat the hell out of it today at 7 pounds.
Old May 13, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
Re: Alcohol thread: UPDATED
That sounds bad....
I have been telling eveyone that pure methanol is the way to go. My dyno with alch was 186 and lean and power curve was chopy. With meth I am running a now solid 230hp at 10psi.
To all with turbo... Use only pure Methanol race fuel from a track.
Old May 13, 2004
MadWheel's Avatar
guns u get my pm? pm me back on anything if u can
Old May 13, 2004
kikoman0's Avatar
kikoman0 is an unknown quantity at this point
i'm using pure race methanol from 76. Cost about 25$ for 5 gallons. Got it through a local race shop called Bozz Performance.
Old May 13, 2004
Mex's Avatar
Mex
is THIS the methanol race fuel I want? (99%)
Old May 14, 2004
fuchs's Avatar
fuchs is an unknown quantity at this point
Here is a new switch. I can't believe I didn't build the injection kit myself. $100
Old May 14, 2004
MadWheel's Avatar
Nice find. I ended up buying a Nos version though, adjustable from 4 to 7psi. Looks similar to those though.
Old May 14, 2004
guns's Avatar
Skyline R33
This is whay I buy it is VP Racing fuel.
Methanol
M-1 Racing Methanol has a 99.95% minimum purity - the highest purity available in the U.S. With M-1, engines run cooler and are less subject to corrosion. VP uses only lined drums which prohibit rust, corrosion and metal deposits that can contaminate fuel delivery systems. Recommended for all methanol-legal racing applications.
Old May 14, 2004
iamboo's Avatar
Retired - SoCal FI Mod
Methanol
this is what i use too...
Old May 16, 2004
MadWheel's Avatar
Also to add to this thread now... So we can clarify this for soon to be boost people as well...
For those running either isopropyl, methenol, or anything else...
List your additive, and what kind of spark plugs you are using, and what range if applicable. For those who do some heavy tuning, anyone think of shortening the gap of the spark plugs a lil to help combustion? If the switch to methanol doesn't work for me, I'll be locating the jet before my BOV to help atomization, if that doesn't work I'll go to some hotter plugs...
Old May 17, 2004
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
That would be me. Starting my SF turbo fund shortly...
Old May 17, 2004
guns's Avatar
Skyline R33
Dude, what are you talking about. Hotter plugs BAD. I am running IK24's, they are 4 ranges colder than stock (stock internals, w/10psi, meth inj.). I blew my HeadGasket again last night. If I am detonating w/ colder plugs I cant imagine running hotter than stock.
Old May 17, 2004
MadWheel's Avatar
If you do more research you'll find out that if you aren't burning all of the fuel you are dumping in, you are running too cold of a spark plug. The idea is to burn the fuel but without detonation. If we retard our ignition timing and went with either stock plug degree, or an Ik20 it should still be ok. But as said before this is heavily influenced by tuning. Different combinations will result.
Old May 17, 2004
guns's Avatar
Skyline R33
I think with 231whp at 10psi is good enough for me, even if I am running to cold of a plug.
But, you are right. My VAFC2 dies not allow for retarding the timing. I am going to look into the Emanage and a thinker head gasket to lower the compression.
Old May 17, 2004
MadWheel's Avatar
I know the 231whp at 10psi is awesome. But you were using methanol, which burns a little better than water/rubbing alcohol. With cold cold plugs, it's very difficult to burn the water injection system, on top of an already running rich fuel setup.
Old Jun 1, 2004
MadWheel's Avatar
Not too revive an old thread, but I think your car handled all that fuel because of the plugs. I did some more looking into... My IK20s are great and are stock gapped, but your IK24s are gapped to .032 instead of the stock .044. That closer gap allows you to burn better, but in the same result, have somewhat of a rougher idle and a sacraficed fuel economy.
I may switch to IK22s which are alse gapped the same as the 24s, but I'm ordering methanol today and I'll see how that works out first.
I bought a WW CF Evo hood and some drag radials so hopfully I can put down some good times this friday.
Old Jun 1, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Gap can be adjusted on all plugs, it doesn't matter. The different plugs just means a different heat range....
Old Jun 1, 2004
opto_isolator's Avatar
That sounds bad....
Wrong. Check out aquamist's website for the proper ratio of alcohol to water - they recommend at MOST a 50/50 mix...
http://www.aquamist.co.uk/rescr/faq/text-a.html#turbo
Scroll down to where it talks about alcohol injection.....Adding MORE alcohol isn't going to help, but in fact HINDER the cooling effect to the cylinder.
10. What is the maximum alcohol/ water ratio I should use?
No more than 50%, otherwise you will increase the cylinder temperature rather than reducing it. Beyond that ratio, onset of detonation is more likely. Methanol freezes at -96 deg. C, 50% mixture will stop the mixture from freezing at around -40 deg.C.
Old Jun 2, 2004
MadWheel's Avatar
Quoted from the aqua mist site...
"9. Why is Methanol better?
Methanol itself has a octane number of 113. Not only does it improve your fuel quality, it will also give you a better intercooling effect in the inlet tract. "
They also say not to use anything more concentrated than 50% methanol, because it will result in an increase in temperature.
I just bought a 5 gallon drum of pure methanol from Worldwide Racing Fuels online. Will be here thursday. Hopfully my plugs can burn up all this fuel. Going to the track this friday.
Old Jun 2, 2004
MadWheel's Avatar
oops i just noticed that opto said the same thing lol, after I saw his link i thought that box was part of his sig... but yeah props to opto for that link, thanks man.
Old Jun 2, 2004
Old Jul 8, 2004
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
so.... how did the Meth work??? better?? a lot better, or a lil better, or worse??? need feedback... and what is a good price for a used Alchy/Meth Injection system?
