ex to lx conversion help
Old May 7, 2004
Samari's Avatar
I remember there was directions on how to do this. Does anyone have it, i have a sf kit coming that is for the dx/lx and i have an ex so i might look into doing this. Help me out.
Old May 7, 2004
djmota's Avatar
or you could get an ex downpipe from sf.
Old May 7, 2004
Samari's Avatar
i could but i want to know if anyone knows about this.
Old May 7, 2004
Jodster's Avatar
Post Whore General
Just take it to a muffler shop and have them shorten your EX down pipe.
Old May 7, 2004
Samari's Avatar
is that the only problem?
Old May 7, 2004
abmerop18's Avatar
Jam out with your clam out.
ya the only problem is the length of the downpipe. just get some custom piping at your muffler shop. should not be more than $100 at most.
Old May 7, 2004
Samari's Avatar
so i can just take it to a shop and tell to cut the pipe and make it bolt up to the downpipe on the turbo.
Old May 7, 2004
abmerop18's Avatar
yup, as simple as that. just a downpipe extension/shorting, not sure which one, but that is all that has to be done.
Old May 7, 2004
Samari's Avatar
thanks a lot man.
Old May 9, 2004
Jodster's Avatar
Post Whore General
Take your Turbo, Manifold, and Downpipe for the turbo with you to the muffler shop. Have them bolt the manifold with the turbo and downpipe on your motor and measure out what they need to shorten your EX downpipe to fit.
Old May 9, 2004
andyman97's Avatar
Turbo Guru
Here's the easiest way to do it.
Once we bolt the entire turbo kit together, we can take off everything after the downpipe. Keep the muffler if you want to use it and find an exhaust shop to put on a 3" testpipe to the muffler and you're good. Shouldn't run more than 100, in fact, Cliff had his done in Shreveport by some guy who only charged him like 50 bux. I got you on that.
Old May 9, 2004
Samari's Avatar
thats cool, but what are they gunna need to do for it to bolt up to the downpipe on the turbo.
Old May 9, 2004
andyman97's Avatar
Turbo Guru
Ok, your kit will come with a downpipe. It should have a flange on the end of the downpipe. All an exhaust shop needs to do is fit your exhaust pipe to the flange on the downpipe. It's not that big of a thing to do. That's why I say, you may as well go full custom now instead of waiting and deciding to do it later. It'll give you much bigger gains.
Old May 9, 2004
Samari's Avatar
sounds good to me
BJB
Sep 14, 2015 11:16 PM
tomas6791
Sep 11, 2015 06:47 PM
Pier7866
Sep 6, 2015 06:54 PM
Broadbeb
May 14, 2015 09:49 PM
AceKicker
Jun 15, 2002 01:01 AM
