SF turbo kit ?
SF turbo kit ?
Ok so after reading some forums and dyno charts and also at truehonda, im still a little confused. Does the SF turbo kit gives 185hp + the 127hp from my EX = 312 or it just brings the car up to 185hp. TrueHonda says Dyno proven to make 185+ whp and 190 ft/lbs on 8 psi, what does that mean?
Originally posted by pr4life36
yea but is with the 127hp from the car or not?
Re: SF turbo kit ?
YOU GOT THE WRONG IDEA ALL AROUND HERE
your car starts out with 127 at the crank 105 at the wheels
a turbo adds power to the car, but u dont just add the two together like you did, 105+80=185 is the type of math u need to be doing
Re: Re: SF turbo kit ?
Originally posted by C2i0v0i1C
TIME OUT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
a turbo adds power to the car, but u dont just add the two together like you did, 127+58=185 is the type of math u need to be doing
it is more like 105 stock whp + 80 whp from turbo = 185 total whp
Re: Re: Re: SF turbo kit ?
Originally posted by abmerop18
you are wrong. hehe. you added a crank HP number plus some other odd number and ended up with the total whp number. you cant add apples and oranges n00b
Hutch1051
Sep 29, 2015 09:20 AM
beanhead
Sep 24, 2015 12:04 PM
