prob with turbo need some help
Old Apr 15, 2004
mndthegap1's Avatar
Unhappy prob with turbo need some help
heres the problem....
when i step on the gas, it boggs down, like it hesitates.
feels like its loosing air somewhere or something like that.
could one of the pipes have popped off ?
or is it due to something else ?
it was running fine up till yesterday, and it just started today ?
Old Apr 15, 2004
civic01vtec's Avatar
check all of your pipes to see if they came loose.
check your turbo mani, might have a exhuast leak. Check to see if the bolts came loose on that too.
Old Apr 15, 2004
civicskater's Avatar
Chicks dig my scent
check your pipes, if you have a manual boost controller that, and even your turbo
Old Apr 15, 2004
C2i0v0i1C's Avatar
SuperMODrizd
might be really rich
Old Apr 15, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Vacuum line off??
All of these could cause it....
Old Apr 16, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
i had that problem too...make sure you fuel lines are hooked up correctly.....i had mine hooked up wrong and it did the same thing...like around 4000 rpm or 3-4lbs of boost...check that and see if it is your problem...also could be running really rich...mine is doing that too..hahah i am just waiting on my safc2 to come in so that i can fix that too...
Old Apr 16, 2004
MadWheel's Avatar
Premium Boosted Member
Also... May be dumb...
If the bog you experience is very brief, check your MAP sensor. Mine went bad, I have a new one that just came in last night the is going in the car along with the rebuild. When I rev it, even it neutral, it hesitates and then eventually picks up. The A/F gauge would also read EXTREMELY lean when it happens, so the MAP will fix it all. If of course that's your prob...
Old Apr 16, 2004
mndthegap1's Avatar
thanks ill check it all out, madwheel since you menitioned the map sensor, would that cause the air/fuel gauge to completely light up ? i have a autometer pro comp series. and just starting yesterday same as the bog down... the air/fuel gauge randomly started completely lighting up like a xmas tree... i mean the entire thing would start flashing then go back to just reading from lean to stoich, and sometimes from stoich to rich. ?
Old Apr 16, 2004
mndthegap1's Avatar
also where can i get a new map sensor ? do i have to go through SF for that? and does anyone know where i can get an O2 sensor for my bank 1 that is reading slow too ?
Old Apr 16, 2004
MadWheel's Avatar
I dont know about the AF gauge completely lighting up, but... I bought mine straight through Honda. Should cost somewhere between $40-50.
Old Apr 16, 2004
dezod's Avatar
7thgen Power Maker
PM me if you need a map sensor.
Old Apr 16, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
Check all vacum lines first. Then check MAP sensor which works off of vacum. Next move to your turbo. Check your wastegate rod and all your piping. Next move to your fuel system. Is your SF fuel pump turning on. You should here a buz sound if it is.
Good luck. I know how frustrating it can be. Be sure and dyno tune it makes a big difference. Running without tuning will cause blown head gasket or worse.
Also you might want to look into the Missinglink MAP isolator. I never had any problems contacting SF. Give them a call and let them know whats going on.
Old Apr 16, 2004
guns's Avatar
Skyline R33
Sounds stupid but when I ran my A/F guage I had major idle problems. I had the sensor wire ran behind the radio. The more I think about it you might have the same problem. Uninstall your A/F guage and see if you still have the problem. The A/F gauge might be some how sending feedback to the ECU.
It is worth a try. Just undo the sensor wire from your O2 sensor or from your ECU where ever it is connected to your car.
Good luck.
Old Apr 16, 2004
bac7213's Avatar
bac7213 is an unknown quantity at this point
na this is the deal, does ur car boost at all??? i mean liek lets say it hits 3500 RPM rigth, does the boost go up or what?? if it doesnt ur car went bad, cuz thats what happened to mine, other then that yea i told mad wheel to buy a new MAP sensor and i did the same n i dont have bogging, n yeah listen to everyone check your pipes n **** like that
Old Apr 16, 2004
bac7213's Avatar
wait my bad lol yea its ur map sensor, mine did the same thing, u stab at the gas n rpm falls for a split sec, and then starts to rev up, its ur map sensor, it probably went bad, u can get one from the honda dealer, but change it and watch it be good as new, also i have my MAP sensor installed without the insulation thing, i guess it depends on the car i dont know but mine works fine
Old Apr 16, 2004
MadWheel's Avatar
yeah I bought a new one through dezod, doesn't take long at all to come in. give that a shot, pm him he get's deals at honda..
Old Apr 16, 2004
mndthegap1's Avatar
yeah i pmed dezod ill prob. order it on moday or tuesday.
as for the pipes i did a quick look and they looked fine. i hear the buzz from the fuel system so thats on... im gonna get a new map sensor and O2 sensor. i just have to check the pipes by the front bumper too lazy to take it off today so tomorrow.... thanks again for everyones help i really really appreciate it.
Old Apr 16, 2004
MadWheel's Avatar
no prob man
Old Apr 16, 2004
mndthegap1's Avatar
if i also buy the safc2 is it really worth it ?
can i really tune the air/fuel ration with it ?
sorry for all the questions, i know i should prob. search this but
since it was mentioned i figured ild just ask
is this it ???? SAFC2
Old Apr 16, 2004
Chicks dig my scent
if u need a missing link i got a brand new one man....i was working on a turbo project but it feel through, send me a PM and i'll get it to you as soon as possible
Old Apr 16, 2004
guns's Avatar
Skyline R33
It helps alot. Read this thread for an example:
http://www.7thgencivic.com/forums/sh...19#post1947519
Old Apr 17, 2004
mndthegap1's Avatar
guns thanks man.... should have searched it but just tooo lazy
Old Apr 17, 2004
MadWheel's Avatar
For the SAFC2 it will definately help, I reccomend the VAFC2 if you have an EX.
Old Apr 18, 2004
fuchs's Avatar
fuchs is an unknown quantity at this point
After I changed the hg...mine bogged down like that for a couple hrs or so. I flooded the engine while trouble shooting. I thought it might be from the fuel soaked spark plugs, but the problem is gone now. WTF??
Old Apr 18, 2004
MadWheel's Avatar
It's ok mine bogged a lil too... Seems to be getting a lot better though, we soaked the coolant and oil up when we took the head off.
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
