do you have this problem (SF boosted ppl)
Old Apr 4, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
do u often hear like TICKING from the engine when pushing the gas? i noticed it most when i was next to other cars.. and my engine noise reflected back at me.
WELL. apparently CAUSE SF's manifold is a FLAT plate and doesnt look like the OEM one where it connects to the block it causes leaks. well MINE DOES. the oem header gaskets keep blowing and causing boost leaks before the turbo. SO. i found this and it works great. no leaks no noise. perfect.
just wanted to FYI about this gasket cause the oem one sucks.
http://www.jdmcrx.com/delsol/products/d17ex.html
then again u could just buy some Mr gasket and make ur own.. but this ones supposed to be better.
Old Apr 4, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Never had that problem my OEM sealed fine.
Old Apr 4, 2004
civic01vtec's Avatar
good find
when i install mine i am gonna use some gasket maker.
Old Apr 4, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
i dont get a ticking noise, but i do know that i have an exhaust leak cause i can smell it around the engine bay....i might have to try that gasket out...thanks for the find...
Old Apr 4, 2004
C2i0v0i1C's Avatar
SuperMODrizd
the only ticking i get is the EBC, and i dont have leaks either, MR GASKET is local, thats tight
Old Apr 5, 2004
fuchs's Avatar
fuchs is an unknown quantity at this point
i can hear a ticking sound coming through my boost gauge when i run more than 6 lbs. i don't know what it could be.
Old Apr 5, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
u have an avc-r.... its the boost controller
Old Apr 6, 2004
fuchs's Avatar
I had it before I even installed the boost controller. Now I can just adjust it not to go over 6. That sucks though...I want more.
Maaachoooo
Turbo
Aug 27, 2015 01:49 AM
Danofthebass
Jun 8, 2015 08:42 PM
Mike Garvey
Jun 7, 2015 07:25 PM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
