oil feed line
Old Apr 1, 2004
civicskater's Avatar
Chicks dig my scent
Question oil feed line
Ok, i was looking on this site Turbo stuff
and it said on the feed line to use a oil feed plumbing method, where you put a NPT into the oil sender on the block, then run the line to the female T that it attached to a brake line or something else, then run the rest of the line to the turbo, is this necessary? Or can i just attach the T to the sender and run the line from that...thanks for the help. I got the oil return done and i think it should work no problem the way its set up now ( hose not braided steel)
also, if i drive my car with the charge pipe hooked up to the intercooler and TB, but no boost running through it, will the engine get enough air? thanks...just wondering
Old Apr 1, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
omg lmao u see this .. this is bad... this is how mine is .. hahaha
i when i say mine i mean the second one.. the one they Really tell u not to do. lol
Old Apr 1, 2004
Chicks dig my scent
yea, because thats the way i was going to do it, but i dont want that bitch breaking off and oil going everywhere...weird man
Old Apr 1, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
well i got a T fitting with the oil sensor on it, then another T fitting on otherside with a 12 inch ss hose going to my gauge sender and my turbo oil feed ss line. lol... yea alot of ****.. ill take a pic tomorrow.
Old Apr 1, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
give me a break...that thing isnt going to break off.. you dont have anything to worry about
Old Apr 1, 2004
Havok2k1's Avatar
Wicked Pissah Admin
I agree, I've seen a ton of turbo systems utilize this method without any problems....
Old Apr 2, 2004
MadWheel's Avatar
Premium Boosted Member
Including myself!!! How badly does your enigne vibrate? The sensor isn't that heavy and the T-fitting is definately pretty sturdy, enough so that it would just "break off".
Old Apr 2, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
use a tuner toys fitting..
Old Apr 2, 2004
fuchs's Avatar
fuchs is an unknown quantity at this point
how did you get under my car to take that picture.
Old Apr 2, 2004
that Nucking Futs
your car was in my parents garage!!!!!!!!
Old Apr 2, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
I had my oil presser sensor(electronic), turbo oil feed, and stock sensor connected to the oil sender. One night when i was out racing the oil pressure sensor broke, oil went everwere. I had to stop at every gas station to refill with oil just to get a to the import shop all the way across town. So now i only have the stock sensor and the turbo oil feed, for now anyway......
Old Apr 2, 2004
Chicks dig my scent
speedracer awesome pic....did you just screw the T fitting into the oil sender?
also, would running just the charge pipe as an air intake with no boost going through it be bad?
Im getting a lot of stuff done this week since its spring break...once i get the SF fuel kit, i'll be boosted
Old Apr 2, 2004
Talking thanx
the only reason i have the elbow on the end of the Tuner Toys fitting is because of our intake mani. i couldn't get the senor to screw in at that angle.Older moldels civics, this isn't a problem.
but yeh, i just screwed it in with some screw locking stuff..forgot the name of it. If not that use some teflon tape..i bought some recently.Only difference is you gotta let the threadlock stuff dry.
2nd question.. not really clear on the question...is everything else hooked up except the wastegate???
Old Apr 2, 2004
Chicks dig my scent
its internally wastegated, the reason i asked was in case i needed to move the car or get parts is if using the charge pipe, as an intake for example would be a problem where it sucks rather than have boost forced into it, but i dont have to worry about it now, the turbos bolted up so im just waiting to build the hot pipe, finish the oil feed line and bolt some other stuff up this week
Old Apr 2, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Some notes to consider:
1. The hole size on the block is 1/8 BSPT, which is British Standard Pipe Taper. It is NOT the same as most sensors which are 1/8 NPT. The main difference is that BSPT has 28 threads per inch, NPT has only 27. Adapters are available and should be used to prevent leaks.
2. Brass is hard, steel is harder, aluminum is much weaker. The problem with adding a bunch of adapters, tees, and sensors is that it does add weight and it does have more leverage when the engine vibrates. What happens is over time, the block's threads are wallowed out and lose their seal. This is the reason to use a piece of braided line and remotely mount the sensors.
3. You don't need the stock oil pressure switch if you don't want a warning light. And there are sensors that also have contacts for the light.
4. Golden Eagle and HKS make spacers that go between the block and oil filter. They have ports already drilled and tapped. They have a 1/8 NPT port and a -8AN line for a turbo. This is a painless way to add a pressure gauge, but they add to the cost.
Cars should all come with an oil pressure gauge. An idiot light is useless. A good gauge can tell you if the oil is thinning, low, thick, or the filter is clogged. And you will tell when the problem is starting, not when it is too late.
ZILLA
Jul 13, 2015 04:52 AM
Hqly2001
22
Jul 12, 2015 06:44 PM
1khilari
Jul 9, 2015 08:12 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
