RSX 320cc Injectors fit our cars
Old May 17, 2004
  #61
canadian2k1si's Avatar
canadian2k1si is on a distinguished road
His fuel system comes with the turbo, but I am still interested in knowing how it works so well in anyone knows?
Old May 25, 2004
  #62
djmota's Avatar
any updates on this subject? Good thread lots of info but no conclusion.
Old May 25, 2004
  #63
ImportRacer2123's Avatar
K20 Member
I want to know as well if they fit or not.
Old May 25, 2004
  #64
opto_isolator's Avatar
Well - I have some used ones on the way, which I purchased from a guy on the clubrsx forums - but I am waiting on them yet....As I said before, they will fit the rail and intake manifold with no issues. The only two issues that remain to be resolved are the mounting stud length on the intake manifold, and if the rail clears the TPS. If it does, than you are good to go. Once I receive them in, you'll all be the first to know....
Old May 27, 2004
  #65
dezod's Avatar
7thgen Power Maker
You'll recieve my injector in 2 days or so according to Fed Ex
Old May 29, 2004
  #66
Update -
Thanks to Dezod I was able to measure the gaps more accurately (Dezod donated a brand new rsx type S injector to the cause - Props to him! ).
It appears that the stock fuel rail, plus injectors will fit, but only by approximately .05" or so - so it will be a tight fit, but it should work!! I didn't actually install the rail on my car because I need to use it tomorrow, and can't afford something to go wrong at the last minute!
However, checking the clearances with those on my car, I'm about 90% certain that it will fit. The only issue I see that MAY cause a problem is that pipe that is welded to the top of the rail. That can be ground off though, and a tube run if that's an issue....
So....until I receive my remaining injectors from a yahoo on clubrsx - I can't be 100% sure....so, if you do this upgrade and it doesn't fit, don't yell at me, because 90% ain't 100%!
Old May 29, 2004
  #67
AzNmiKex215's Avatar
2k1civic.com O. G.
once this thing is confirmed working. Do you think this will change the turbo kits for D17's in the future? Do you think every kit will probably just come with the upgraded injectors + some type of fuel computer? Is this the better fuel solution for forced induction? pros / cons?
Old May 29, 2004
  #68
I think it will change things a little - but you have to remember that new rsx-s injectors are like $95 / piece!! Adding new injectors to a turbo kit is going to cost a LOT....Used injectors may be a lot easier to find, but of course, they are used. The rsx-s injectors are rated for around 330cc's around 50 psi I believe.....if you had the emanage, and a return system (such as I have) you can bump the fuel pressure up a bit, which I plan on doing. Maybe around 55-60 psi or so, just to squeeze more fuel out. Granted they are more expensive than RC engineering injectors, but are a direct replacement (ie, hardly as much work installing them than the RC's).....
Old May 29, 2004
  #69
K20 Member
i can't wait for the answer to this.
Old May 29, 2004
  #70
tripledoublegs's Avatar
Euro-Spec
anything new on this issue?
Old May 30, 2004
  #71
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
man opto, i have to give you mad props for doing this....also for all the info you gave me on the return conversion when i requested it...i am going to try and tackle that next weekend...thanks man....
Old May 30, 2004
  #72
iamboo's Avatar
Retired - SoCal FI Mod
if you guys don't wanna buy the rsx injectors importparts.com through honda-tech.com is offering a good deal on RC injectors...
http://www.importparts.com/honda-tech.html
Old May 30, 2004
  #73
I have an injector size question here:
http://www.7thgencivic.com/forums/sh...38#post2052138
Old Jun 1, 2004
  #74
Bump--any news if they are a match?
Old Jun 11, 2004
  #75
K20 Member
Which RC injectors fit our cars? Also what modification is needed?
Old Jun 11, 2004
  #76
Well I just got them - but I would like to flow test them as well just to be sure before putting them in the car, that way there's less chance that I will damage anything....
Old Jun 11, 2004
  #77
HyaBoosta's Avatar
sounds promising. good luck opt
Old Jun 11, 2004
  #78
K20 Member
opto: how long is that going to take?
Old Jun 14, 2004
  #79
HyaBoosta's Avatar
bump for some progress
Old Jun 14, 2004
  #80
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
I wonder how opto's doing??
Old Jun 14, 2004
  #81
I just sent them off to have them flow tested - should take 2 days to get there, than he'll test them, send them back, and I'll install them....
I need to know the flow rates to enter as close of guess into the Emanage as possible for the injector correction.....I won't know if it works or not until than. Of course, SF hasn't been much help with my manifold either - so I can't really do much until I get that too......
Old Jun 15, 2004
  #82
Awesome, only a few more days then..
SF
Old Jun 18, 2004
  #83
Hwoody77's Avatar
Hwoody77 can only hope to improve
Bump...Opto how's it coming along?
Old Jun 18, 2004
  #84
Big Baller L's Avatar
Nugget Garage Since 2004
yah if this works im thinking of rsx injectors and a safc for fuel management. Hopefully it will work out. Let us know what you find out.
Old Jun 19, 2004
  #85
cwick187's Avatar
cwick187 is an unknown quantity at this point
Damn,this is intresting!!! Let us know
Old Jun 21, 2004
  #86
HyaBoosta's Avatar
been a few days now. i wonder if opto got the injectors back from flow testing?
Old Jun 21, 2004
  #87
Not yet - he's testing them today....should have results later today for the flow test (hopefully!)....
Old Jun 21, 2004
  #88
HyaBoosta's Avatar
sounds good. can't wait to see if they fit!
Old Jun 21, 2004
  #89
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
WOOHHOO
i wa gonna bump this today too because i thought i saw it on page 2
Old Jun 23, 2004
  #90
Ok - just received my injectors back from Mirage (thanks again bro!)...
The RSX-S injectors flowed pretty consistant, I am throughly impressed! At 43.5 PSI, here are the results:
injector 1 - 342cc/min
injector 2 - 339cc/min
injector 3 - 339cc/min
injector 4 - 341cc/min
injector 5 - 337cc/min
4 of the 5 injectors were used, with about 20,000 miles on them....These seemed to held up well for the milage....and I only paid $50 for them!
So - flow rate is roughly 340cc at 44 PSI - bump this up to 50 PSI and flow rates should increase to a decent # (possibly around 360cc's).
This is good news - next step is to install them. The plan is to possibly see if they fit, but I don't plan on running them until my turbo kit is in (the emanage would need to be tuned due to difference in injector size - and I don't plan on paying for tuning twice).
