Big Turbo
Old Mar 24, 2004
player's Avatar
Big Turbo
i was thinking, what would happen if u put a turbo that is too big for an engine. example if u boost 15psi on a d17, what would happen?
Old Mar 24, 2004
MadWheel's Avatar
Premium Boosted Member
well 15 psi isn't related to turbo size at all... so ignore that...
anyway, the bigger u go, the more power, to a certain extent...
a larger turbo also takes longer to spool up, so take into consideration what kind of driving u plan on using it most for. the best setup i feel is a t3 super 60. anything smaller may limit u if u start building, bigger is better but only if u want to sacrafice some lag...
ask if u need more...
Old Mar 24, 2004
tdiddy's Avatar
tdiddy is an unknown quantity at this point
The exhaust probably wont be able to spin it. Or you would have major turbo lag.
Old Mar 24, 2004
MadWheel's Avatar
It'll be able to spin no matter what, just damn slow lol...
I have a T04B now, it takes a lil while but after 4k it pulls so nice...
Old Mar 24, 2004
player's Avatar
oh the exhaust spin explains it. but what i am trying to get at is, doesnt a bigger turbo mean air that is more compressed? and is there something as air being too compressed for an engine.
Please excuse my ingorance and noobness
Old Mar 24, 2004
MadWheel's Avatar
It's ok...
I bigger turbo means more CFM for the same psi. A smaller T25 can produce 15psi just like a T3 at 15psi.... The T3 will make more power because at that compression, more CFM is still flowing into the engine.
Old Mar 25, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
CFM?
Old Mar 25, 2004
MadWheel's Avatar
cubic feet per minute... a bigger turbo has a larger cfm than a smaller turbo at the same psi, which is why they generate more power
Old Mar 25, 2004
Havok2k1's Avatar
Wicked Pissah Admin
CFM has a small amount to do with it...
It's about volumetric efficiency. Bigger is not always better. The turbine's design will dictate the efficieny at a certain psi...
Old Mar 25, 2004
MadWheel's Avatar
Yup yup.
ricer_em2
May 11, 2016 08:09 PM
HondaGuy7
Feb 22, 2016 01:00 PM
Tedverseti
Sep 29, 2015 05:41 PM
anubis62
Sep 27, 2015 12:56 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
