turbo swap
Old Mar 7, 2004
vandejr93's Avatar
vandejr93 is an unknown quantity at this point
turbo swap
I have a 91 eclipse w/blown engine, would it be too difficult to swap the turbo kit on the civic (2002) using the turbo, down pipe, inter cooler and lines from the eclipse??? has anyone done this setup??
Old Mar 7, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
it wouldn't de a direct bolt on but that is given.
a new mani and your gonna need some additional piping plus fuel management and gonna have to modify the downpipe if not make a new one
evverything else should be straight
BOV
turbo
some rubber chare pipes
injectors( might need to be modified)
it's just a homemadeturbo setup
Old Mar 7, 2004
vandejr93's Avatar
modified injectors dont understand and exhaust and piping i can do but why fuel management. how much.
Old Mar 7, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
Well fuel management meaning alcohol injection or a greddy emanage or a vafc, etc etc.
Injectors meaning, your DSM injectors will NOT fit the 7thgen civic, or any DSM injectors, or RC's or RX7 injectors blah blah blah. They're all about an inch or so too tall. Hence...the alcohol injection or the other means of fuel management. Other means are only good for upto 7 or so PSi though. If you want higher, you'd need to upgrade your injectors in that case. And well....just read up man there's plenty of info on it.
Anda s mentioned before, the manifold, piping, down pipe, and dump tube (if external w/g) will most certainly be different. Oil lines you might be able to use...but you have to check lengths.
runawaykinms
15
Mar 22, 2019 10:32 AM
Jaryn
May 17, 2016 02:52 AM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
DatGuy_Robb
Sep 3, 2015 08:08 AM
justcruzin125
Aug 11, 2015 09:09 PM
