T04/E turbo?
Old Mar 4, 2004
shawnskee22's Avatar
local 7thgen rugger!
shawnskee22 is an unknown quantity at this point
T04/E turbo?
i searched but didnt really understand what i found . what exactly is a T04/E turbo, what is the differance between it and others and will it even work for our cars? basically i am just curious about it and would appreciate any and all info you can give me. if you know something about it then please post it.
Old Mar 4, 2004
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Re: T04/E turbo?
the T04E is the compressor end. It's used with hybrids like T3/T04E, T4, etc etc.
It's significantly different than the t3 and T04B compressors in size and such. I wouldn't go any bigger than a T3/T04B. If you learn how to use compressor maps, you can look it up for the differences. But basically, depending on the build, T3's and T04B compressors on our engines put us in and around the 70% efficiency range. The T04E is lower based on our engines. I haven't seen the T25 compressor maps, but I'm assuming they would be a bit higher. 70% efficiency is the target range for choosing a turbo (there's a lot more, but I'm not going into that). Outside of that range though...the effects are different. One way is compressor surge nad a hotter chargte, the other is more lag but a cooler charge (provided the IC is the same). Bottom line though, I wouldn't choose a T04E, it wouldn't be a proper match. I'm uncertain of whether it will fit without switching to a thinner fan profile. My T04B is snug against the engine block, and part of the fan shroud had to be shaved still.
Old Mar 4, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
^^ what he said.
BTW....that thing i posted about garret turbos.....it has alotta info. someone should make that a sticky. I posted it in some guy who posted "what kind of turbo" or somethin of the like.
Old Mar 5, 2004
SpdRcrChk's Avatar
BOOST JUNKY
Been stickied....here's ur link. Read up.
http://www.7thgencivic.com/forums/sh...hreadid=142883
Old Mar 7, 2004
yeah i had read all that when i searched. thanks for the help.
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
