A few swap ?'s
Old Mar 3, 2004
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
A few swap ?'s
Alright, i came across a pretty good deal for ALL the required parts to do a k20a2 swap (from the hassport website) from a junkyard for $4200, trying to talk the price down a little more, since i need to buy mounts from hassport which is another 6 bills
getting to the point. If i don't do the 5 lug conversion, won't the odometer/speedometer be off? i mean aren't the overall wheel diameter of the rsx and the vic different? (this the mph reading will be off, and the rev readings will be off too?)
also, if i get an aftermarket alarm, do i still have to worry about the whole immobilizer problem?
Thanks guys!
Old Mar 3, 2004
ricergribbs's Avatar
ricergribbs is an unknown quantity at this point
i dont think the rpm's would be off since that has nothing to do with your wheels... and the speedometer might be a little off but i dont think it would be too much to worry about. use the "tire calculator" on this website its on the left in the menu area.
Old Mar 3, 2004
§C§H§O§C§O§B§O
thnx gribbs
Old Mar 3, 2004
oh, actually i checked, your tach will be reporting the correct rpms, but the engine might rev differently then it would with the stock tires. but then really that would happen if you get rims on a stock civic.
Old Mar 3, 2004
and be careful if its an automatic since that might screw up shift points so you might go past redline.
Old Mar 4, 2004
§C§H§O§C§O§B§O
its 6 speed manual
Old Mar 4, 2004
§C§H§O§C§O§B§O
also, since u have to swap the ECU, will you be able to directly hook up the RSX gauge therefore bypassing the need to get hassport's harness?
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
