another question on turbos
Old Mar 1, 2004
2k1vtec46's Avatar
2k1vtec46 is an unknown quantity at this point
i got a 2003 EX and i've heard that turbos could f***up your engine if your engines not reinforced and stuff, if i want to boost 8 psi what kind of reinfocing do i have to do if any?
Old Mar 1, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
At 8 Psi...with alcohol injection, you really don't HAVE to do anythin'.
If you want to do internals in the future, do a search. I'm sure there's hundreds of posts about pistons, rods, rings, head jobs, etc. etc.
Old Mar 1, 2004
civic01vtec's Avatar
at 8psi u will be fine if properly tuned. If you wanna boost higer than that, say around 11.....i suggest some new pistons. If you wanna go higher than sleeving the block is a must.
Old Mar 1, 2004
RiceBuRNeR's Avatar
Turbo Member
I ran 9 psi every day w/ no alch injection and I had no problems. When I cranked it up to 11-13 however I cracked my head gasket.
Old Mar 2, 2004
SpdRcrChk's Avatar
BOOST JUNKY
9psi isn't bad.
What size turbo were you or are you running and what are you doing for fuel?
Old Mar 2, 2004
Spider883's Avatar
9K Redline Owns U
tuning is everything
Tedverseti
Apr 23, 2020 01:45 PM
-HondaFTW-
Aug 30, 2015 10:38 AM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
justcruzin125
Aug 11, 2015 09:09 PM
