Timing Issue with Turbo
Old Mar 1, 2004
Ahtasham's Avatar
Ahtasham is an unknown quantity at this point
Ok I did some search but didnt find what I am looking for.
What I want to know is that by installing the SF Turbo kit and running 10 psi (once in a while) on a complete stock engine and leaving the ignition timing as it is, what would be the result in terms of engine damage etc. ????
Thanks!
Old Mar 1, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Re: Timing Issue with Turbo
Thanks!
With force inducted engines it is common practice to retard the ignition curve. With SF kit and alcohol injection, you "should" be fine at 10 psi especially if its only once in awhile. If you are worried or can't bounce back from any problems that may occur, I would advise you not to push the engine that far.
Old Mar 1, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
With alcohol injection, timing retard shouldnt really be necessary. And if you WERE to attempt it...I wouldn't do it without a dyno session. You should be FINE at 10psi. I just wouldnt run it like that for "daily" driving.
Old Mar 1, 2004
opto_isolator's Avatar
True - however one has to remember that with alcohol injection it all depends on how good of an alcohol system is installed. You can't just slap a spray nozzle in the charge pipe and call it a day.....The alcohol dispersion pattern has to be consistant enough so that it is distributed equally (or close to) between cylinders - otherwise you really aren't getting the best benefit from it (ie cooling effects). This is why I don't plan on running one. You cannot be sure if all of your cylinders are getting the same amount (or any for that matter) - damage is more likely to occur than if you did things properly and retarded timing up top....
Just my $.02....
Old Mar 1, 2004
civic01vtec's Avatar
general rule of thumb is.....for every increase of 100 hp, you should retard the timing 1 degree.
Old Mar 1, 2004
SpdRcrChk's Avatar
BOOST JUNKY
Opto's right!!! Good job.
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
Supramk3
May 11, 2015 07:55 PM
Supramk3
May 8, 2015 11:16 AM
mikevtec
May 3, 2015 01:36 PM
cloudguy
Apr 28, 2015 05:02 AM
