Oil return line?
Old Feb 28, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
Oil return line?
I am going to install my turbo kit in the am. I never got the no weld oil pan tap from SF. Would drilling the whole and then using a tap thread the hole. use a threaded fitting. on the inside and outside of the oil pan use a nut on the threaded pipe and jb weld it all together. That should hold up good. Right? Any suggestion?
Old Feb 29, 2004
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
Buy an oil return line kit from: http://www.fast-turbo.com/Turbolines.html Stan is a great guy and will get you setup. You can PM him on Honda-tech his sn is: Flamenco-T
Old Feb 29, 2004
guns's Avatar
Skyline R33
thanks for the link. but I plan to do the install tomorrow. I will try and rig something up and use JB weld to seal it all up. I dont know if you have ever used it? But the stuff works good. I will post pics of what ever I come up with.
Old Feb 29, 2004
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
did you PM catalysy to ask what parts they use and if they'd be readily available at some store? It's better to use something they rigged up that works, then to go through the trouble of trying to rig something yourself. Worth a shot at least
Old Feb 29, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
I have been talking to Stan (Flamenco-T) about buying his return line kit with the no-weld fitting. He is a great guy I'll post pics when I purchase and install. The SF rubber hose is not satisfactory for my setup.
Old Mar 2, 2004
guns's Avatar
Skyline R33
Here is a picture of what I ended up using. All found at pepboys and truvalue hardware. No leaks and running boost thanks to Speed Fetish.
Old Mar 2, 2004
Your Parts Guy
What was the reason for not making any boost? Sorry just curious.
Old Mar 2, 2004
guns's Avatar
Skyline R33
The plastic vacum distr. piece cracked so had vacum leak. I had the brain box on vacum and it needed to be on the piping. The bottom piping from turbo to intercoller blow off. No map sensor isolator. Bad boost controller. Several small things. But Speed Fetish( another plug for them) hooked me up.
RIPSAW
Nov 6, 2015 04:36 AM
Black91civic
Jun 6, 2015 08:15 AM
JoeB16
61
Oct 16, 2003 07:58 PM
drbombay
Feb 5, 2002 02:38 PM
