custom turbo application on 2001 EX civic
Old Feb 25, 2004
  #31
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
The one in that picture may not be an actual D17 log manifold. It may just be a sample of what he makes. But what you receive does indeed matchup. I know....I've seen his manifold first hand.
Old Feb 26, 2004
  #32
B17boost's Avatar
B17boost is an unknown quantity at this point
i would have never guessed that e/m ment exhaust manifold. as for the flange patterns i didnt know they were different from the regular d16/5's. Basically all you need is a flange with undrilled bolt patterns then mock it up. Also, do they have mount kits for B's into the 7g's? i cant recall ever seenin one.
What are the differnece in spec for the 1.6 heads to the 1.7?? If the bolt patterns are different then somthin inside has to be.
Also whats with the 1.7, isnt it stroked. Anyone used the crank in a diff motor and made good power? Hit me with links I dont get on here much or have time to search.
1.7's gotta love um wether B or D series hah
Old Feb 26, 2004
  #33
cambo's Avatar
I wish I was asian
basically...almost everything has changed. nothing is swappable between the d16 and the d17.
Old Feb 27, 2004
  #34
SpdRcrChk's Avatar
BOOST JUNKY
EXACTLY ^^^^ what he said.
Everythin's different now. From the direct ignition system, to the returnless fuel system, to the manifolds. Everythin's very different.
To answer one of your questions....no there is not a b series mount kit out for 7th gen's (even though there ARE K series kits for EK's, and EG's I believe) . Although I've heard "rumors" of be series kits for 7thgens...I Just don't think it's legal in most (if not all) states to put a motor in your car that's older than your car ( i could be wrong? )
Old Feb 27, 2004
  #35
B17boost's Avatar
ya your right about that motor age swappin thing, i totally forgot about that.
speaking of K powered EKs heres a boosted k20 in a EK'
Old Feb 27, 2004
  #36
SpdRcrChk's Avatar
BOOST JUNKY
Did ya find that on Honda-tech?? I think I saw that there once. Was a red EK too.
LionSpratt
Jan 29, 2017 11:07 PM
Dave
Feb 3, 2005 06:21 PM
locozoko
Apr 6, 2002 09:00 PM
aZnVoYCe
Dec 7, 2001 12:41 AM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
