sf turbo iat sensor?
Old Feb 20, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
is it me or am I the only one without a hole in my intake piping for the iat sensor?
Old Feb 20, 2004
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
I didn't have one either on my piping. The shop just weleded one in. Took no time.
Old Feb 20, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Re: sf turbo iat sensor?
I don't have one either but it's on my list of things to do this weekend. I have the gromet from my AEM intake and the little connector that goes into it for the sensor. I just need to be careful not to drill the hole too big or else i'll have a boost leak.
Old Feb 20, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
same here, but it needs to be done... car will run better with it installed
Old Feb 20, 2004
civic01vtec's Avatar
i am gonna install the gromet from my AEM CAI like dober said
Old Feb 20, 2004
jwcardy's Avatar
i am worried about that...thought about it, but isnt it still possible that it could blow out under boost....have you guys talked to cat or mike about this
Old Feb 20, 2004
Your Parts Guy
I havent talked to them about it but I am willing to take the chance. I am going to drill the hole so that the gromet just barely fits. I am doing it this weekend I'll post pics.
Old Feb 22, 2004
Ahtasham's Avatar
Ahtasham is an unknown quantity at this point
I asked about this sensor thing from Catalyst once, dont remember his exact words, but he said its NOT necessary and he hasnt got it plugged either in his own car.
Old Feb 22, 2004
Your Parts Guy
Not necessary for what? The car to run? No it is not necessary for the car to run. But you have to think that Honda would've elminated it if it was truly unecessary. The IAT is used by the ECM to make calculations and adjustments that is why I am going to drill a hole myself and connect the sensor. BTW you will get a CEL if it is not hooked up or "tied off".
Old Feb 22, 2004
Boosted2k2's Avatar
I drove around for a month without the IAT in the pipe. It doesn't do much. It's only purpose would be to trim the injector pulse, and a tiny amount at that. It probably just gives a factor to the MAP to adjust the volume. I'm assuming that if you're using the SF fuel kit, it wouldn't really make a difference, since the fuel kit doesn't really depend on the injector pulse, but depends on the pressure to force it through. I run on a return fuel system, and it didn't change anything before or after it was in.
You won't get a CEL unless you actually cut the sensor off the wires.
Old Feb 22, 2004
Your Parts Guy
I have a CEL for IAT sensor and didnt cut any wires. I took it to discount auto for a free scan and it gave me two readings. One was the IAT and one was for o2 voltage (running rich).
Old Feb 22, 2004
jwcardy's Avatar
yeah, i didnt cut the wires to mine either, and i got a cell for it, but i cleared it and it hasnt come back
Old Feb 22, 2004
Boosted2k2's Avatar
Hmmm. Never happened to me. That's kind of wierd. The CEL is just a probe, if it's not in the pipe, why wouldn't it just take the temp under the hood as the air temperature (not much different if it were plugged into a stock airbox). Unless it hit a hot part of the engine, your underhood temps are pretty hot, or there is just something wrong with the sensor.
What did it say about the IAT sensor?
Old Feb 22, 2004
jwcardy's Avatar
Hmmm.
it just said that the temp was too high...i think that that is what was wrong, that it may have touched a hot spot on the engine
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
BootyDo
Jun 21, 2016 03:45 PM
Dani1993
Jul 24, 2015 09:02 AM
Theshwartz35
Jul 18, 2015 10:49 PM
mistermenphis22
Jul 13, 2015 04:43 PM
