Oil leak from oil return on turbo
Old Feb 21, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
alright, i got the rest of my stuff in from SF a couple of days ago and i installed it yesterday afternoon.....i installed the oil return flange that attaches to the bottom of the turbo and i even had a gasket made for it, but i am still having an oil leak from there.....i know that this is where it is coming from.....what did you guys use on your setup, set as rubber silicone or what, to keep from having an oil leak.....it is a little one, but yet it is aggrivating and is messin up my concrete driveway.....
Old Feb 21, 2004
jwcardy's Avatar
oh and this has nothing to do with SF so i dont want anyone to start bashing them like they seem to do in all the other threads that i start.....
Old Feb 21, 2004
opto_isolator's Avatar
Are you sure its not the center section of the turbo itself (ala the oil seals rather than the oil return)?
Old Feb 21, 2004
jwcardy's Avatar
well, i did notice a little drop around there while i was putting everything on but i assumed that that just got there from the return setup....if so, what does that mean....
Old Feb 21, 2004
If your oil seals are bad, than the turbo will have to be rebuilt (ie, taken completely apart) - just to replace them. They are what hold the oil in the bearing section (so it doesn't flow into the compressor and turbine sections). They may be leaking - it happens....Contact SF and see what he says, take some photos if you can.
Old Feb 21, 2004
jwcardy's Avatar
damn it
Old Feb 21, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
I had the same thing but I used gasket maker and everything was all betta
Old Feb 21, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
use red silicone from pepboys.. .. un bolt it ... put some all around it ... bolt it back up and let it dry over night.
Old Feb 22, 2004
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
if the oil seals were bad, you would have quite a bit of smoke coming out the exhast of your car.
Take the flange off, clean both surfaces really well, then use some high-temp silicon to seal it.
Old Feb 22, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I have quite a bit of smoke coming out of my exhaust still ... any idea what parts I would have to take apart? ... pics? =\
Old Feb 22, 2004
Your Parts Guy
What kind of oil are you using? My 5w30 mobil 1 is getting past the seals and building up in the lower IC pipe.
Old Feb 22, 2004
jwcardy's Avatar
i am using mobil 1 10w 30 NON synthetic i DONT have any smoke coming out the exhaust....alright, thanks guys.....going to get me some silicone
Old Feb 22, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I'm using Honda (Mobil 1) 10w30 oil ... in certain weather, it smokes a bit a couple seconds after I press the gas from an idle...
hm, could it also be that I don't have a cat? ... O_o ... but I guess it wouldn't matter if I had a cat or not, because that crap never came out when I was n/a ... -_-;
Old Feb 22, 2004
Catalyst's Avatar
azn, i talked to your friend at the meet. I told him what you needed to do, and i am going to send you the part.
Email me with your address and ill send it to you asap. It literally takes less than 5 mins to install. And i had the same problem, and this fixed it.
LionSpratt
Jan 29, 2017 11:07 PM
RIPSAW
Nov 6, 2015 04:36 AM
671civicLX
Jun 13, 2015 05:56 PM
davidpaustin
May 20, 2015 12:59 PM
Grey
16
Jan 27, 2002 11:34 PM
