Nitrous Kit HELP
Old Feb 19, 2004
WhiteCivic2K2's Avatar
WhiteCivic2K2 is an unknown quantity at this point
Nitrous Kit HELP
Hey all,
I was just offered a Dry ZEX nitrous kit and guage for my seats.
question is can i run a 35 shot of dry nitrous without a problem
NEED an answer asap
Thanks
Old Feb 19, 2004
corbeaucivic2nr's Avatar
corbeaucivic2nr is an unknown quantity at this point
i hot a 50 shot wet no prob. i don't think you can run dry on the new civics
Old Feb 19, 2004
hmmm ne way to convert the dry kit to wet kit.
Or any way to mod the engine to run a dry kit
Old Feb 19, 2004
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
whoa whoa whoa. the dry is kit is perfectly safe on civics just don't overdue it. 35 dry shot will be fine on our cars if installed correctly. search for more info.
Old Feb 19, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
uh you sure about that? a dry kit adds fuel by pressurizing the FPR and seeing as how ours is in the tank and isnt vacuum sourced it wouldnt work at all. wet is the only way to go unless you convert to a loop style fuel system
Old Feb 20, 2004
scansel912's Avatar
i was aware that the dry kit doesn't deliver extra fuel, only nitrous into the air. Therefore it doens't matter what type of fuel system we have. Search and you will find many people run dry shots on their 7thgens.
Old Feb 20, 2004
scansel912's Avatar
Yea i just found like 5 posts saying they have dry shots and some people are even going up to 75 shot but i wouldnt' recommend that unless you really know what you are doing.
Old Feb 28, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
WRONG. Not all dry kits add fuel in that sense.
Matter of fact, the VCN1000 (Venom) dry kit adds fuel by connecting to your stock injectors and pulsing them.
Dry is perfectly fine on our applications, however, the higher the shot, the less fuel you're gonna be able to compensate with (even if it does connect to ur injectors OR an FPR). VAFC (or SAFC) might help. I wouldn't go higher than a 50 on a dry kit....however....75 on a wet is perfectly doable.
Either way White..... your seats for that kit....i'd say not worth it. Get urself a nice wet kit. You'll be fine.
Old Feb 28, 2004
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
I've heard many good things about the compatibility between our Hondas and the NX kits and thats what I run. No regrets so far
Old Feb 29, 2004
tfnaaf's Avatar
BLDNPSI Mod
NX kit kicks @$$ i LOVE mine!
Old Feb 29, 2004
Smile
Me too....money well spent!
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
ttamrekab
Sep 28, 2015 01:22 AM
anubis62
Sep 27, 2015 12:56 AM
beanhead
Sep 24, 2015 12:04 PM
