RSX type S swap compatibility
Old Feb 18, 2004
triver525's Avatar
triver525 is an unknown quantity at this point
How compatible is the running gear from a type-s RSX? I have an opportunity to get a donor car and swap the engine, tranny and suspension but I just don't know how much of a "drop in" it will be. I imagine the rear suspension will be a direct bolt on but what about the front? Anyone have any experience?
Old Feb 18, 2004
meth's Avatar
meth is an unknown quantity at this point
check out www.hondawerx.com they have all the info you'll need for the swap.
Old Feb 19, 2004
Drivetofast's Avatar
Supercharged k20a3
Drivetofast is an unknown quantity at this point
almost everything is the same, the rear suspension will fit expesuly if you have everything
Old Feb 20, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
things to add on your "shopping list"
hasport wire harness
hasport mounts
si radiator
si axels, if you are doing the 5 lug conversion i think you can use the rsx axels too
rsx brake master cyl if doing rear disk conversion with 5 lug
custom exhaust to connect cat to the muffler
extra set of 16's if doing 5 lug and disk conversion if you have to experience winter
rsx shift cables
rsx subframe
si power steering pump, if you dont wanna mod your hood
an intake... not sure if the stock one will fit properly
hondata ecu heheh yea yea
that should be able to get you up and running...
Old Feb 20, 2004
ViNRoCk8's Avatar
#1 S2000 Fan
hasport mounts
si radiator
rsx shift cables
rsx subframe
If your swapping in the si motor you use the si's shift cable and subframe right, you don't have to use the Rsx stuff......
Old Feb 23, 2004
WannaBFast's Avatar
you forget, the si shift lever is in a totally different location from where the normal civic is.. you are gonna need to use the rsx ones
as for the subframe, its the same if its from the ep3 or the dc5
Old Feb 23, 2004
Hawk's Avatar
You boost, I-VTEC
Everything you need is here
trust me hasport knows what they're talking about.
The rear spindles from the RSX will bolt up to the Civic trailing arms. Your gonna need to take off the RSX's ebrake cables, and brake cables. For the front you need to take of the RSX abs sensor, i forgot to do that one. And use the RSX struts, the knuckles won't bolt up to the Civic struts.
If you look through my members ride section you will see that basically everything from a RSX will bolt up to a Civic with little to no modifacations.
Old Apr 19, 2004
82801BA's Avatar
82801BA is an unknown quantity at this point
Well....I have my 03 Civic EX knuckles bolt up to the RSX Type-S struts, without any modification(except the tie rod end)
Old Apr 20, 2004
Hawk's Avatar
You boost, I-VTEC
there wasn't play in the 2 bolts that connect the shock to the knuckle? on my car the rsx had wider holes on the knuckles, thats why i used the rsx struts.
Old Apr 29, 2004
ramoMan's Avatar
ramoMan is an unknown quantity at this point
Besides the engine, what was the final cost? installation and mod's
Amulon
Aug 18, 2015 11:03 AM
CraigW
Aug 18, 2015 07:06 AM
Misfit2613
Jul 30, 2015 09:49 AM
Kyle Cargazm
Jul 16, 2015 02:06 PM
