Octane Boosters in Alcohol Inj?
Old Feb 17, 2004
Ahtasham's Avatar
Ahtasham is an unknown quantity at this point
I was wondering if its possible to use octane booster fluid for Alcohol Inj instead of Alcohol?
Would it have the same effect or make things worse?
Thanks!
Old Feb 17, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
good question... insnt octane boost supoose to be mixed with a full tank of gass? i dunno
Old Feb 18, 2004
Ahtasham's Avatar
Yes octane boosters are meant to go in the fuel tank e.g. a bottle of octane booster mixed up with the whole fuel tank.
But if used in the pure (concentrated) form, by pouring directly into alcohol injection tank, without any mixing, would it do the same as alcohol???
Old Feb 18, 2004
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
i don't think so, cause octane booster only raiser the octane in about .xx and alcohol raises it complete points,a nd isnt octane booster toulene?
Old Feb 18, 2004
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
octane booster is expensive as hell compared to a good alcohol fuel... i pay $15 for a full 5 gallon drum of methanol, works great... just use that..
Old Feb 18, 2004
Ahtasham's Avatar
Well that makes sense (depending upon the availability). Do you use methanol in its pure form? or a 50/50 mixture with water?
Old Feb 18, 2004
civic01vtec's Avatar
just use it straight....it's pretty cheap
Old Feb 19, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
where do you get your drum of methanol at........... is there anything else that we can run in it that we can get from any regular store
Old Feb 20, 2004
RiceBuRNeR's Avatar
Turbo Member
Where the hell do you buy it that cheap? I buy denatured wood alcohol from home depot for like $3.99 a gallon!
BTW: jwcardy if you read the back label of a can of denatured alcohol it says it is a clean burning fuel......contenets: methanol. So its the same stuff you just pay more for it.
Old Feb 20, 2004
RiceBuRNeR's Avatar
Turbo Member
Running it straight will just raise combustion chamber/ Exhaust gas temps and take away all the good efects of methanol injection. Read the High Performance Honda Builder's Handbook by Joe Pettitt. He explains in detail water/methanol injection. Also he explains every aspect of turbocharging a honda engine. Its a great read and you can pick it up for about $20.
Old Feb 23, 2004
so, how should u mix it ?
Old Feb 23, 2004
RiceBuRNeR's Avatar
Turbo Member
I know that 50/50 is safe I heard 60/40 some-where but I never tried that..... Too much water wont hurt the engine but it will hurt performance. Too much alcohol will still stop detonation but produces too many BTU's and can cause hot spots.
Old Feb 23, 2004
yeah, i've always been wery on injecting water into the combustion chambers.
Does this apply to alcohol too?
Old Feb 24, 2004
RiceBuRNeR's Avatar
Turbo Member
People have been using straight water for years. mixing alcohol w/ the water just helps you gain back any power your loosing from the water while stopping detonation. Alcohol releases more BTU's than gasoline when it burns so too much is bad.........50/50 should be fine.
thaler4cuse
Sep 7, 2015 08:25 PM
shaejb15
Jul 27, 2015 03:48 PM
fvckbg
Jul 7, 2015 07:08 PM
crazyjetskier
May 17, 2002 07:02 PM
BassmanJP
Apr 10, 2002 10:11 PM
