Spooling Question
Old Feb 13, 2004
ThsUserNmIsDumb's Avatar
Currently boosted at 0 psi.
ThsUserNmIsDumb is on a distinguished road
Spooling Question
Well, I'm not very knowledgable about forced induction, and I came across two questions today:
A) Using the SF kit, at approximately what rpm does the turbo begin to spool?
B) What causes a turbo to spool at different rpm's on different cars? Is it just that each car releases a different amount of exhaust at hte same rpm?
Thanks in advance.
Old Feb 13, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Hard to say when it starts spooling but my profec reads positive boost at around 3k. It also depends on how you get on it because you will build boost at a different rate.If you have an EBC like I do you will also see different results based on the settings of the unit.
Old Feb 13, 2004
Thanks.
Old Feb 13, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
yeah what he said
Old Feb 13, 2004
civic01vtec's Avatar
it also depends on the turbo itself. The fins are mounted on a shaft. The shaft has weight to it and and the bigger the turbo the bigger the fins/shaft. It's like rolling a tire....it is hard at first, but once it gets moving it gets easier and faster to turn. When applying throttle sometimes the car will seem gutless then all of the sudden it is picking up, this is known as lag....b/c the turbo is starting to spool and is gaining momentum. The smaller the turbo, the less lag. Lag can be decreased by using a small shot of n2o.
Why do i keep rattling on? I'm tired
Old Feb 13, 2004
jwcardy's Avatar
yeah, what he said too
Old Feb 14, 2004
Your Parts Guy
Love your input on this thread!!!!
Old Feb 14, 2004
Hehe. Thanks, guys. I know what turbo lag is, but I was just wondering what caused it. Makes sense, actually. A lot of things do once you put your brain into the equation.
Old Feb 15, 2004
ziggyboo84's Avatar
ziggyboo84 is an unknown quantity at this point
you wanna have all your turbo questions answered as well as a couple of moore??? check out this site http://www.beesandgoats.com/boostfaq...ml#TurboBasics
Old Feb 15, 2004
Wow, thanks.
Old Feb 15, 2004
ziggyboo84's Avatar
i'm glad i could help setting up a custom turbo kit is not as easy as it seems i would suggest the last thing to buy is the turbo it slef cuz that will require the most research becuase there are so many differen ratios you can go wiht just search search search and read lol
Tedverseti
Apr 23, 2020 01:45 PM
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
