MSD Ignition for DIS systems
Old Feb 9, 2004
andyman97's Avatar
Turbo Guru
Well, it's out there. I had been searching for ways to retard timing and I found an msd ignition for distributorless ignition systems. It lists at about 330 which isn't horribly bad. I plan to pick up one of these relatively soon. No more need for alcohol injection. You can find it at summit racing.
Old Feb 9, 2004
RiceBuRNeR's Avatar
Turbo Member
I've been looking at that too, but jegs said they didnt think it would work on our 3 wire system. Each coil pack has a ground, 12v+, and trigger wire.
Old Feb 9, 2004
andyman97's Avatar
Turbo Guru
Definitely worth looking into. I wish I could find someone who has some experience with it.
Old Feb 9, 2004
MadWheel's Avatar
Premium Boosted Member
All I need is a 2-stage rev limiter. I need something to pre-spool the turbo, without over revving.
If anyone knows what will work please enlighten me. My car is being setup for race use (full course throughout the year, with dragging for occasional tests).
Old Feb 9, 2004
andyman97's Avatar
Turbo Guru
One of my friends is using a 2 step on his gsr. I'm not sure if it was through his hondata but I'll ask him and do some research on that as well. Trying to find out what will and won't work on our cars.
Old Feb 10, 2004
MadWheel's Avatar
I apreciate that, however, the GSR ignition systems are COMPLETELY different than our cars so it would still be different from him.
I may just break down and call MSD sometime this week.
Old Feb 10, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
This DIS system is designed for cars such as the Mazda Miata and Protege that use a coil pack and camshaft positioning sensor instead of a distributor, and not coil on plug as we are. Coil on plug is a totally different system from DIS. DIS is where you have a coil pack with spark plug wires leading to each cylinder's spark plugs, instead of having the coil pack directly on top of the spark plug as we do.
MSD is reportedly in development of a coil on plug system much like the Ignition Solutions setup that I have, and should be released sometime around middle summer.
Old Feb 10, 2004
MadWheel's Avatar
Ahhh thanks man. Good to hear.
Old Feb 10, 2004
RiceBuRNeR's Avatar
Turbo Member
You can use a BEE* Racing rev limit, it has an adjustable "stutter box" feature that is great for drag launches.
Old Feb 10, 2004
MadWheel's Avatar
really? where can i find that? is it safe?
Old Feb 11, 2004
RiceBuRNeR's Avatar
Turbo Member
I was looking in to buying one for my car. It interupts your ignition at a pre set RPM as long as you have the remote launch button held down. This also causes flame to shoot out of your exhaust b/c your not interupting the fuel pump like a stock revlimit so its actulay less harsh on your car and will keep the turbo spooled at launch. You cannot retard your timing w/ it, but you can set both your drag launch and soft touch main rev limmit w/ it.
I cant remeber the website though, just search for BEE Racing. Also there up on ebay from time to time.
Old Feb 11, 2004
MadWheel's Avatar
damn can't find them
mjdiaz89
Jun 21, 2016 09:26 PM
Dani1993
Jul 24, 2015 09:02 AM
cukaracha
Jul 17, 2015 05:48 PM
