Gonna boost, need input!
Old Feb 11, 2004
ricergribbs's Avatar
ricergribbs is an unknown quantity at this point
ok, ive finally decided! ill go turbo. ok so tell me if any of this stuff is pointless or if i need something else. what kind of #'s would i get? and how much would be a safe lvl of boost to run daily with these mods, i have a 2001 lx automatic.
full catback exhaust
aem pulley kit
spark plugs
turbo kit
crank pulley
grounding kit (heard gives better idle/throttle response)
cam gear
greddy emanager
turbo timer
dhracing head port
lower compression(8.6-8.8:1) forged pistons
torque converter
tranny cooler
tranny racing upgrade
resleeve the engine
this is everything i have in my engine build list(want to be sure of what im doing before i even start). any suggestions? numbers? comments? ideas? etc?
edit: thanks to all who posted so far, i forgot to add im looking for about 250-300hp, would i even need all these things i listed to make sure the engine is still reliable and still run enough boost to produce these numbers?
Old Feb 11, 2004
Got Boost???'s Avatar
you prolly already thought of this but a boost gauge is a must. Too many people are somehow running way too much boost and dont even know til its too late.
Do you know what kit you are going to be getting??
Also who handles the tranny upgrades?? I wasnt aware that anyone offered any auto tranny upgrades.
Old Feb 11, 2004
deciuss's Avatar
Boosted Auto
www.levelten.com has upgraded auto trannys
Old Feb 11, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
If you're going that far, you might as well add:
oil cooler
forged connecting rods
balanced and micropolished crankshaft
oil pressure gauge, wideband o2 display and datalogger, fuel pressure gauge
fuel pump
fuel pressure regulator
return fuel line
ditch the Emanage and get the AEM EMS. with the amount of money you're spending, you won't get the best results or safest tune without a full standalone. Emanage is just a piggyback.
larger injectors, how big depends on power you intend to make
There is more, this what I can think of off the top of my head. You're also going to be able to make the kind of power that trashes transmissions and snaps half-shafts, so be prepared for things like that.
Old Feb 11, 2004
First to spool
Revised from your edit and PM....
For 250, you can get away with a lot less. For 300, you need just about the whole list.
For 250whp, add these things to your list and you'll be fine:
boost, EGT, fuel pressure, and oil pressure gauges
bigger injectors, and the Emanage is just fine
inline fuel pump to use with stock intank fuel pump
wideband o2 if you plan to tune yourself, otherwise the dyno guy will have one
The DHRacing head port would not be necessary, but it would be nice and it will help your power output.
If you have a big stereo system, ditch the AEM pulleys, they can cause problems with the alternator after time with a large stereo draining power.
bowie
Jan 21, 2018 09:29 PM
C-Hamm
Sep 28, 2015 10:31 PM
Luluharp
Sep 27, 2015 11:56 AM
speedlever
Sep 24, 2015 07:18 PM
99BoostedSi
Sep 7, 2015 04:49 PM
