Hydraulic Clutch Relocation
Old Feb 8, 2004
civicstreetrcr's Avatar
civicstreetrcr is an unknown quantity at this point
Hey Im doing my custome turbo . Today I finally got the Manifold And Turbo To Fit In But
The Problem Is where the clutch is at the bottom i Unscrewed it ANd I need To Know If theres a "RELOCATION KIT" Because My Clutch Pedal Wont Go Up Anymore??
ALL HELP WILL BE APPRECIATED AND I WILL POST PICS ON MY SETUP TOMORROW.
Old Feb 8, 2004
RiceBuRNeR's Avatar
Turbo Member
Do you mean the clutch slave cylinder?
Old Feb 8, 2004
HTOWNBOY's Avatar
HTOWNBOY is an unknown quantity at this point
did you bleed it? you might want to use a vacuum pump to bleed your clutch.
Old Feb 8, 2004
No its in front of the block by the middle of th Manifold.
Its held by 2 bolts.
Old Feb 8, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
slave cylinder for sure....mine just went on my hatch...not sure about relocating it tho
Old Feb 8, 2004
I was trying to move out of the wat you think that wouldve caused it ? or do you think maybe something popped out when i moved it?
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
speedlever
Sep 24, 2015 07:18 PM
powman02
Sep 15, 2015 07:38 PM
Klame9420
Sep 7, 2015 10:03 PM
