SF alcohol injection DIY needed
Old Feb 4, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
hey guys, as most of you know i have ordered my SF kit and will be doing the install this weekend, if my other parts arrive in time. what i want to know is if any of you that have done the install with the alcohol injection, can post a DIY on the alcohol injection...... pics would be nice too, so that everyone(including me) can see exactly what is going on...... i have been told by several, that it is easy, but i would really like to see a DIY of this to go along with Catalyst excellent DIY on the turbo install
Old Feb 4, 2004
civic01vtec's Avatar
ibtl
Old Feb 4, 2004
hahaha, i'm just kidding..........i would like to know too
Old Feb 4, 2004
jwcardy's Avatar
some how i knew that you would be the first to post in here
Old Feb 4, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
why cause hes a whora
Old Feb 4, 2004
jwcardy's Avatar
yes.........i would have hoped that this would have been and informative thread
Old Feb 4, 2004
Your Parts Guy
at least you got your kit lol...i have pipes that are predrilled for alcohol injection and didnt even ask for it. maybe some day ill buy the alchi injection kit
Old Feb 4, 2004
jwcardy's Avatar
well, i dont have the alcohol kit..... they forgot to put it in the box, but they were suppose to mail it out to me today so that i can have it by friday(2day air)
Old Feb 5, 2004
i'm not a *****, i would like to know too
Old Feb 5, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
no DIY needed..... its one wire from power to the pressure sensor then to the windshield wiper tank....
Old Feb 5, 2004
RiceBuRNeR's Avatar
Turbo Member
^yes you are a post *****
Old Feb 5, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
ok here look..
install the injector/sprayer... doesnt matter where.. just near the TB.. if the holes arent already tap'd then ull need to goto NAPA and buy a 1/8 npt tap.
Old Feb 5, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
^^^ btw .. that orange crap up there is what holds my IAT sensor in
then install the pressure sensor... install this ne where BEFORE the injector.. i used the back of the elbow pipe...
run a wire from a constant power source...i used my fuse box... connect the wire to the pressure sensor.
then connect another wire from the OTHER SIDE of the sensor to the windshield wiper motor located on the tank(turn wheel and remove wheel wheel plastic crap to access)
i believe the power wire is the blue/white wire.. cut the blue/white wire and connect the wire from the pressure sensor to rest of the blue/white stripe wire still connected to the pump.
NOTE: this disables the use of the windshield wiper nozzles.
TO test :
take a piece of wire an connect each sides of the pressure sender... this sends a postive threw the wire connected to the pump and u should be able to hear the pump and see the nozzle spraying..
Old Feb 5, 2004
jwcardy's Avatar
ahhhhh, thanks for the diy.......
Supramk3
May 11, 2015 07:55 PM
ORskier
May 7, 2015 04:54 PM
BootyDo
May 7, 2015 04:46 PM
CivicVoz
Apr 16, 2015 08:07 PM
Myredjonda
Apr 14, 2015 07:00 PM
