Turbo Help!
Oil is coming out of your breather filter on your crankcase, or your air filter (intake)?
If it's the intake, bad oil seal on the turbo, bent valves, or many other horrible things. Most common is bad oil seal on turbo tho.
If it's the breather filter... a LITTLE oil coming out is normal. More than a few drops after a very hard run usually signifies blown rings. If it's gushing... might as well pull the motor and rebuild.
Originally posted by Gotti
sf > yu0
sf > yu0
Anyways, you can have blown rings and still have most of your power. Do a compression check and then a leakdown test if you do have a lot of oil out your intake and have checked your turbo's oil seals. Do a few tests before you worry too much, it could be something simple and easy to fix.
sf > yu0
sf > yu0
Jaryn
May 17, 2016 02:52 AM
