type r vs. type s
Old Dec 18, 2003
hondaciv01's Avatar
hondaciv01 is an unknown quantity at this point
Question type r vs. type s
i know i want an k series motor, and i used to be positive that i wanted the type s motor. but now i am looking at the rsx type r motor, but i have a few doubts. first of all, since it is not made in the u.s., will aftermarket parts be very difficult to get? And is the price difference worth it for the extra 20hp that the type r has? If you can, tell me the price difference between the two, that would be appreciated.
Old Dec 18, 2003
eklipz's Avatar
not sure about price..but i beleive its the new super street has a 7gc w/ a k20 r swap...somone correct me if im worng
Old Dec 18, 2003
hondaciv01's Avatar
i've found a type r motor with everthing needed to make it work for 5800, but i can't find the price of the type s
Old Dec 18, 2003
Jaykuai's Avatar
ish...
are you going turbo a later time?
because if you are.. then Go S (if cheaper)
S got lower compression.
Old Dec 18, 2003
Jodster's Avatar
Post Whore General
^^^^^^^LOL Type S has 11 to 1 compression. The Type R has 11.5 to 1 compression.
There are a lot of difference between the K20A and K20A2. Search. This has been talked about lots of times.
Plus I seriously doubt you will be able to get everything you need for $5800. What about a new radiator? K20A3 axels? Or are you going to swap your suspenion out to be a 5-lug. What about Hasports mounting kit or their wiring harness? Plus all the other little ends and odds needed to complete the swap.
K20A2s run for about $4000.
Old Dec 18, 2003
Jaykuai's Avatar
ish...
^^ doh.. i thought it was less..
hehe
Old Dec 18, 2003
eklipz's Avatar
*correction* its the Jan 04 Honda Tuning that has the 7gc w/ the k20 r....but man u should see it its such a sweet car...nice widebody 2
Old Dec 18, 2003
hondaciv01's Avatar
yeah i saw that car, and i loved it
Old Dec 18, 2003
WorldsSlowestEm2's Avatar
tried searching. at this moment in time, with the 4 reputable shops in my area, the type-r is a lot easier to find than the type-s
Old Dec 19, 2003
eklipz's Avatar
how could it be alot easier to find...type r is not in us...type s...just search some junkyards and there ya go
Old Dec 19, 2003
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
www.car-part.com
thats where i got my $520 d17 shipped
Old Dec 19, 2003
Anotherslo1's Avatar
Anotherslo1 is an unknown quantity at this point
I'd go with the type-s. It is cheaper and you can make it street legal if desired because of U.S. specs. The type R only has like 20 more hp and about 18 pounds of torque. <--off the top of my head> Hondata does have a chip out that will give you Type-R specs. I've seen prices for the Type-s and Type-r and there actually about the same. Don't forget you will need the steering column, and key to make things easier or you will have to pay Honda to reprogam your old transponder on your key to talk to your new ECU. Type-S is better way to go I think, and chip it. If you need help just send me a tell.
Old Dec 19, 2003
Jodster's Avatar
Post Whore General
^^^^^^Ok I'm going to correct you. The K20A2(Type S) goes for around $4,000. The K20A(Type R) goes for around $5500. You get more than just extra hp and tq. You get LSD, higher compression, more aggressive cams, aluminum oil pan(keeps the oil cooler), higher redline, and a few other things.
No matter which one you get, take your car to Honda and have the reflash your key code to the new ECU. DO NOT switch out the steering column. Unless you want to have to use two different keys. One to unlock your car and one to start it. It only cost lke $60 to have them reflash it. Not a big deal.
Old Dec 21, 2003
hondaciv01's Avatar
yeah i read about that...there was some really wierd trick to get it to start once, but it was really complicated.
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
Cam Diaz
Sep 29, 2015 07:17 PM
anubis62
Sep 27, 2015 12:56 AM
speedlever
Sep 24, 2015 07:18 PM
