k20a2 swap
Old Dec 8, 2003
krazyjon's Avatar
krazyjon is an unknown quantity at this point
k20a2 swap
ive done many searches and i have not come up with what i want to know
soo here it goes
ive read all the articles about the swap being done, and im willing to swap but i have not seen any slips/dyno's of the k20a2 swap in a 7th gen.
boost will bring me to about 14-13 1/4 mile but i would have more potential with the k20a2..I can go NA with the k20a2 and get better numbers than a boosted d series with stock internals
anyone have any slips or dynos or links to any webpages that actually state real numbers to what this swap can do in our cars?
Old Dec 9, 2003
hondaciv01's Avatar
hondaciv01 is an unknown quantity at this point
i think it's somewhere close to what the rsx type-s would get cause i heard the cars weigh about the same....i'm not positive though....i would like to to get some real numbers as well....either way, i'm buyin a k20a2
Old Dec 10, 2003
yellowcoppy95's Avatar
yellowcoppy95 is an unknown quantity at this point
k20a2 engine swap troubles
can anybody out there forsee any problems with the following: i have a 2001 honda civic 2 door ex and i want to swap an rsx tpe s engine into my car. the only thing is that i have an automatic. what do i need to do to perform this swap without any complications. i work at a honda dealership so getting someone to do the swap is not a problem, i just need to know if it is doable and how much it will be.
Old Dec 10, 2003
RSXtypeIvtec's Avatar
Su Mo
yes its do-able.....prolly cost you around 4-5g's the least plus labor (dont know how much that would be since you probably know the techs at the dealership).
gonna have to get all the manual transmission links and cables to swap that out to convert to the 6-speed.
i believe the civic weighs about 100 pounds lighter than the rsx-s, so shouldnt be too much of a difference.
then your gonna have to buy all the necessary componets: subframes, ecu, motor...blah blah
this may help: http://www.hondawerx.com/kseriesswapparts.htm
Old Dec 10, 2003
krazyjon's Avatar
nice link
Old Dec 10, 2003
Anotherslo1's Avatar
Anotherslo1 is an unknown quantity at this point
There is no problem with changing the auto to manual on the swap. If you have the tranny and all it will be fine. Only problem you might encounter is you have to drill a new hole in the firewall to allow the clutch through. This is solved because on the EX, there is already a hole there. It has a rubber filler in its place. If you gonna do the swap make sure you also get the steering column and key. This will save you a lot of money, because if you don't you have to reprgram the transponder in the key to communicate with the ECU. You will encounter a lot of problems as for price I might be able to hook you up if you in cali area. My sponsor has step by step process when we did a coordinated swap with HASPORT. Us and HASPORT took 4 months to figure swap out back in the day. But thats because we did everything right. You will also need different parts for some items in your swap. If you have questions, just email me and I'll answer all I can!
Old Dec 10, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
actully the clutch cable linkage will be in the floor.
you will also need keys programmed to work because of the stupid immobilizer.
Old Dec 10, 2003
I meant the pedal!
Old Dec 10, 2003
deciuss's Avatar
Boosted Auto
2 months ago i called a place that does a really nice job on swaps from my home town to see how much it would cost and how much i needed to save. they said 8grand for every thing plus some insurance on the swap for a few months.
so the swap for 8k would be for a 2001 4 door ex auto.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
