NoS minus the NoS ?
Old Dec 4, 2003
tfnaaf's Avatar
BLDNPSI Mod
NoS minus the NoS ?
Anyone ever run NoS with the valve closed so all your getting is extra fuel?
Old Dec 4, 2003
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
i done it before, it will bog with the extra fuel.
Old Dec 4, 2003
tfnaaf's Avatar
BLDNPSI Mod
im just wondering that if u played with the fuel jet that you could get increases in HP without the use of the nos. Sorta like bigger injectors?
Old Dec 4, 2003
Diemos's Avatar
Diemos is an unknown quantity at this point
Re: NoS minus the NoS ?
All you are doing is running rich, thats a retarded idea. Because there isen't more oxygen to compinsate for the additional fuel, thus the additional fuel burns poorly and people will see dark smoking coming from your tail pipe, plus you will fail emmisions.. You will lose horsepower if you do this.
Old Dec 4, 2003
andyman97's Avatar
Turbo Guru
Not sure if you can adjust the jets on the nitrous the same but I've use a wideband and tuned my fuel without the turbo under 75 percent throttle or higher and it actually makes for better throttle response. Remember, these cars were made to conserve fuel.
Old Dec 5, 2003
tfnaaf's Avatar
BLDNPSI Mod
Well for Sh*t's and giggles today i installed the 30hp jets in the nozzel and took it for a spin...... Automatic trans mind you 2nd gear take off , at around 3000 RPM I FLOORED it, THEN flicked the switch on for the Nos with the Bottle OFF! and i noticed a surge in HP just shy of what i did with the Nos ON. ZERO BLACK CLOUDS out the exhaust! Im going to maybe try the next larger Fuel jet and try it again. BTW I checked the Plugs just after the run, looked clean no rich condition that i could see. I'm kind a curious how it would run down the 1/4 mile on just the extra shot of gas?
Test car = 01' AT, injen CAI, and DC sports TCS exhaust
Old Dec 5, 2003
andyman97's Avatar
Turbo Guru
Yep, that's about right. Just be careful. Rich conditions over time can wash out your rings. I wouldn't give too much extra fuel unless you have a good a/f reading off of a wideband. Yeah, I guess it is kind of stupid <note my sarcasm> to think that adding fuel can give a better response and any noticeable gains lease:
Old Dec 5, 2003
PlatCruiser's Avatar
PlatCruiser is an unknown quantity at this point
Looks to me its time to get your butt dyno recalibrated.
Old Dec 5, 2003
Diemos's Avatar
Agreed. If anyone actually thinks flooding your engine is a good idea they need to be taken aside and have the mechanics of an engine explained to them, or shot.
Old Dec 5, 2003
tfnaaf's Avatar
BLDNPSI Mod
Whom said anything about FLOODING an engine? I sure didnt. What i was trying to get at is sometimes peopel add larger injectors for increase fuel, and by me running JUST fuel on the nos maybe , just maybe it was acting on the same principal. I was just trying to spark some thought and get input from others. But WTF was i thinking you obviously know alot more about air fuel ratios and what will and wont work
Old Dec 6, 2003
andyman97's Avatar
Turbo Guru
Don't sweat it bro. Some people think they know everything there is to know about everything just so that they can feel important. You know what adding that little extra fuel did, doesn't matter what anyone else "thinks."
charmon4815
General
Sep 22, 2015 08:00 AM
Civic720
Sep 10, 2015 10:06 AM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
mistermenphis22
Jul 13, 2015 04:43 PM
speed werx
Mar 19, 2002 09:07 PM
