Finished my tranny swap
Old Nov 7, 2003
  #31
IronFist's Avatar
The numbers on a manual Civic's tach are farther apart than on an auto Civic's tach. On a manual, 12 o'clock is like 4500 and on an auto it's like 5500.
Old Nov 7, 2003
  #32
Elite's Avatar
Elite is an unknown quantity at this point
I just recieved my revo ss in the mail, omg it looks so much better especially with that shift **** I got, the throws are way shorter and feels a lot better, can't wait till capyoda recieves those bushings, and I will get the upgrade kit from grey.
Old Nov 7, 2003
  #33
Elite's Avatar
the tach works fine, there is no difference, once you change the dash then there is a difference, I plan on buying the whole thing. But right now I can't afford it. I'm saving for my turbo, and I need to fix that axel, because its not working like I said. it costs $340 at the dealer, so im waiting for my mechanic to tell me if the guy has found one for me car prolly like 100 bux. The cv joint popped out because its a lot shorter. And my car got stuck in nutreul, it didn't want to catch a gear. I dont have my car right now, im trying to save as much as money as possible because I practically work a minimum wage job. I'm suprised my parents took it so well. btw the auto ecu works with the manual tranny. Just the check engine light comes on.
Old Nov 7, 2003
  #34
Elite's Avatar
oh and the d blinks on the dash
Old Nov 7, 2003
  #35
ExOrCizT's Avatar
ExOrCizT is an unknown quantity at this point
Originally posted by ImportRacer2123
Oh My God You don't have your license yet? And you have an 02 civic? wtf is wrong with the world these days
hey.. i cant complain
Old Nov 7, 2003
  #36
ImportRacer2123's Avatar
K20 Member
LOL your lucky
Old Nov 10, 2003
  #37
K20 Member
Okay well im looking at Geoff's (NoBottleJustThrottle) Complete Motor well now its mine so I can do the tranny swap. $400 too I am looking at the swap being done by Thanksgiving!
Old Nov 11, 2003
  #38
ExOrCizT's Avatar
wouldnt it be alot cheeper just to do an engine w/manual tranny swap
Old Nov 11, 2003
  #39
K20 Member
im doing the swap with my buddies so there is no labor fee.
Old Nov 12, 2003
  #40
AzNmiKex215's Avatar
2k1civic.com O. G.
props to you!! you are one of the pioneers.
maybe one day once the 8th or even 9th gen civics come out. their will be premade wiring harness u can buy that have all the bugs worked out for this conversion.
i dont mind waiting.. i will have my civic forever.. lol
Old Nov 14, 2003
  #41
Elite's Avatar
well i waited too long to get the mounts installed on my tranny now my motor mount broke, and my p/s hose busted, because the engine would move forward, and jerk back, because of the 6 puck clutch, my p/s pulley would hit the hose, and it busted, makes a nasty noise, and my stupid mechanic forgot to put the bolt back into the water pump metal hose, my car overheated, but not that overheating problem is fixed now. I didn't know how much damage a 6 puck clutch can do, break mounts really quickly. Oh btw the clutch never overheats, it just smells like syrup now because of the fluids leaking everywhere, esp with my car squirting anitfreeze everywhere.
Old Nov 14, 2003
  #42
Elite's Avatar
oh yeah i ripped the boot for the axel now its throwing grease everywhere from the boot, minor problem, I'm not ridin gmy car until I get my hood/ mounts fixed for my car. Other than that, I need to grease my accelerator pedal because it gets stuck once in a while especially when I punch it.
Old Nov 14, 2003
  #43
Elite's Avatar
I'll kee you guys updated on the pics, I'll show you what I'm talking about.
Old Nov 16, 2003
  #44
K20 Member
Holy **** man that sucks thats why im going to go with a Stage 3 Race Clutch. not that 6 puck clutch. I'm sorry to hear things are not working out. Hey did you have to use the 5-speed wire harness? I'm taking that as a yes
Old Nov 26, 2003
  #45
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
So the total for the manual swap was $1700us rite? I am thinking to do mine, and I have a 2001 civic LX and this is all the parts i need for
this manual swap?
Tranny
Shift linkage
shifter assembly
pedal assembly
master cylinder
slave cylinder
clutch, flywheel, pressure plate
clutch line
wiring harness dash
engine harness
axels
subframe
Old Nov 26, 2003
  #46
K20 Member
Radatior Fan and Hoses as well i think. ECU too if you want it done with no CEL.
Old Nov 26, 2003
  #47
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Hence the reason's a 6 puck isn't recommended for a street car lol... even a fairly heavy modded street car. I can't believe someone actually installed that without questioning it. Good luck though. Good job too.
A stronger clutch isn't good unless it somewhat matches your output. Too much friction will cause damage to your axles, or completely shatter the disk or tear up the pressure plate. Too weak and you'll just slip and burn up. Better to slip a little than to grip too much. I have 13000 miles on a ACT HD Pressure Plate and an Organic Street disk. Holds 8psi like a champ with no slipping, just grips. And that kit is perfectly matched IMO. There isn't even a need to go with the XTreme or anything above HD (for those using ACT anyway). You would either 1. Slowly be screwing something up or 2. Losing more drivability (:::think feather::.
Old Nov 26, 2003
  #48
jdm_bb's Avatar
How come need to change the radatior fan and hose? the manual are different than the automatic? and what do u mean by CEL?
Old Nov 26, 2003
  #49
Elite's Avatar
the 6 puck I have is very nice it doesnt jump anymore with my new mounts in place which was the reason why it was breaking in the first place, you do not need the radiator either the auto will fit both. I think the 6 puck is awsome and my friend said that the short shifter I got was the best one he was driven also.
Old Nov 26, 2003
  #50
Elite's Avatar
CEL=Check Engine Light
Old Nov 26, 2003
  #51
Elite's Avatar
oh btw I also bought the whole deal because the guy told me that the 6 puck will eat my stock flywheel like no other so I decided to buy the act flywheel 11 lbs which is 2 pounds lighter than stock. I dont want too light because I am going turbo.
Old Nov 26, 2003
  #52
jdm_bb's Avatar
so do u have any problem after doing the manual swap?
and ur cluster is auto what's it like when u have that in a manual
cause the rpm is suppose to be longer than the automatic
Old Nov 26, 2003
  #53
Elite's Avatar
I have no problems and the auto cluster works fine.
Old Nov 28, 2003
  #54
2k1civic.com O. G.
is your pedal spacing different then a factory manual?
Old Nov 28, 2003
  #55
Elite's Avatar
no I got stock pedal sets and most of the holes were already premade and stuff.
Old Nov 29, 2003
  #56
K20 Member
im getting alot closer to my swap. Im gettting everything i need before I start the swap.
Old Nov 29, 2003
  #57
Elite's Avatar
most of the holes were already there because I guess honda tries to save money or something.
Old Nov 29, 2003
  #58
K20 Member
lol Elite and I found out that my honda dealership are morons
Old Nov 30, 2003
  #59
vvii's Avatar
vvii is an unknown quantity at this point
great job, i think many people will only think of doing this swap, but actually not many people will doing it, and you are the man .... ,best of luck for the rest of it.
Old Nov 30, 2003
  #60
K20 Member
My Mom Said no i can't do the swap.... LOL Like im going to listen to her im 18 she can't stop me or can she?
