so close, yet so far away
Old Oct 29, 2003
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
About 3 weeks ago i went to a junkyard and pulled a k20 out of an RSX. I have pretty much the main stuff to do the swap. motor, tranny, ecu, subframe, etc.... But there is so much little stuff that i need like Axles im gonin with the 94 GS-R ones. civic si radiator and fans, is there no way to use our raidator and fan. Radiator hoses, RSX fuel line, brake booster line, purge line, clutch line from master to slave cylinder. And some other crap. Can anyone offer any advice on where to get the parts at a resoniable price? By the way what is the intermediate shaft? not sure if i need that to.
Old Oct 29, 2003
Jaykuai's Avatar
ish...
you should go and get the rsx you just ripped out and get all that from it.
Old Oct 29, 2003
atl01's Avatar
allot of that suff was allready missing.
Old Oct 29, 2003
Jodster's Avatar
Post Whore General
FYI the 94 gsr axels do not work. You need to get the K20A3 axels.
Old Oct 30, 2003
atl01's Avatar
where did you here that at?
Old Oct 30, 2003
Jodster's Avatar
Post Whore General
From the guys here that have done the swap. PM Nobottlejusttrottle or Hawk Both of them know what is needed and they can give you an idea of where to get everything.
Old Oct 30, 2003
atl01's Avatar
I was just going by what is on hasports list on there web-site. Well that sucks because the GS-R alxels are a lot cheaper than the RSX ones, but i only need the passanger side alxel i allready have the driver-side one.
Old Oct 30, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
yea well u need neither... rsx is 5 lug, and the gsr's dont fit..
u need the 2003 SI ones.
Old Oct 31, 2003
atl01's Avatar
I called hasport this morning, they said that they make swap axels $400 a pair. not bad.
Old Nov 2, 2003
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
good luck with the swap man....u may just wanna buy the axles from a parts store with lifetiume warranty like most people do with swaps so when they break take em out get new ones without waiting forever....im a few hours away in fl if u need any help id deffinately like to help all i can on a weekend or something were gonna be having a meet the 15th in Destin FL. if ur interested pm if u want to go
Old Nov 10, 2003
NytRyder2k2's Avatar
Bay Area
I just picked up a k20a3 and i hope i will be able to find the parts for cheap also. If you have any problems with the swap send me a PM because i will have to be doing it soon as well. Good luck
Old Nov 10, 2003
pitciv's Avatar
pitciv is an unknown quantity at this point
how much does a k20 cost at a junk yard??
Old Nov 10, 2003
Em2Guy's Avatar
Em2Guy is an unknown quantity at this point
yo GSR axels will NOT WORK!!! I found out the hard way
very similar but it will not lock into the tranny. I ave witnesses :-P
Old Nov 11, 2003
atl01's Avatar
So what axels did you use Em2Guy?
Old Nov 11, 2003
Jodster's Avatar
Post Whore General
Use the 02 and up SI axels.
Old Nov 11, 2003
atl01's Avatar
Yeah, ill pass on using the 02 si axels i called south honda today, try $800 each. Ill sell the motor and forget the swap before i pay that much. And i called a number of junkyards trying to find a wrecked si and no luck. I paid that much for the motor and tranny.
Old Nov 11, 2003
Jodster's Avatar
Post Whore General
Look around man. Check some different forums. Ephatch.com Honda-tech.com And look on ebay and such.
Whitexj
Sep 30, 2015 02:04 AM
Islesfan
Sep 29, 2015 03:42 AM
Matt T
Idle Issues
Sep 24, 2015 04:53 AM
emiixo
Exterior
Sep 22, 2015 03:53 AM
Yang559
Transmission
Sep 21, 2015 01:41 PM
