Turbo Compression
Old Oct 28, 2003
XxJDMCivicxX's Avatar
Turbo Compression
Ok I got a question about compression, I was talking to a guy in my mechanics class today and he said that when you get a turbo installed it raises your compression, that sort of made no sense to me so care to example if hes right or wrong plzz.
Old Oct 28, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
It probably made no sense to you because you were thinking Comression ratio and not compression itself. With a turbo, you are forcing more air than you would N/A, so that extra air has to be compressed the same as the N/A. Because you have more air and it's being compressed the same... you have a higher pressure in the cylinder, hence... it's compressed higher. The compression ratio still stays the same though. There is no change in the volume of the cylinders.
Old Oct 29, 2003
Once again Boosted2k2 you rule
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
runawaykinms
15
Mar 22, 2019 10:32 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Sep 27, 2015 11:33 AM
NROD315
Sep 12, 2015 02:46 PM
