turbo timer help
turbo timer help
to anyone ho has installed their turbo timer, i was wondering if you could help me out with something. i cant find the speed sensor wire in the ECU, i read the DIY and searched like a **** but found nothing. i know the wire is #18 and is wht/grn but me and 3 other people looked at my ECU and couldnt find a damn wht/grn wire
all ECU wiring is the same? (i have a 02 AT EX coupe, if that makes any difference). so what i need from you guys is if you some how remember which wire it was PLEASE TELL ME!
or even if you only remember close to where it was located, i'll settle for that too! cuz when your looking at the connector there are 3 rows across and 12 rows down. i already tried 4 different wires but none was it. thanks for the help.
or even if you only remember close to where it was located, i'll settle for that too! cuz when your looking at the connector there are 3 rows across and 12 rows down. i already tried 4 different wires but none was it. thanks for the help. Hey! Look At Me!! I'm a Supporting Member!!
It depends whether he meant vehicle speed or engine speed (RPM).
-Vehicle Speed:
***MT/AT***
ECU Connector A
Terminal 18
White/Green
***CVT***
ECU Connector E
Terminal 25
Blue/White
-Engine Speed (RPM):
ECU Connector E
Terminal 26
Blue
-Vehicle Speed:
***MT/AT***
ECU Connector A
Terminal 18
White/Green
***CVT***
ECU Connector E
Terminal 25
Blue/White
ECU Connector E
Terminal 26
Blue
Here's a trick that I used. look at the HUGE plug in front of the ECU. There is two wire bundles connected to eachother with a large harness. If you slide the harness (either up or down - kinda forgot lol) you can unplug the harness. You'll have a left side and a right side once seperated. Look on the "right" wire pack, even though they are connected to eachother... There will been the white with green stripe wire. That's the one to tap.
18secQuaterMile wrote on <font color="blue">Today</font> 08:21 PM:
sorry to keep bugging you about this but i have on last question and i swear i'll leave you alone, lol
i got the RPM wires hooked up but i cant find the speed sensor wire for my life. i know its #18 and its a white/green wire but i looked, my dad looked, my friends looked and none of us found a wht/grn wire. i have a 02 EX AT coupe, are all ECU wiring the same? if you have your speed sensor hooked up, do you perhaps remember where abouts the wires was, like say your looking at the connector while its plugged in, the RPM wire was on the right hand side near the middle. is the speed sensor wire in the right, middle, or left row? i already spliced into about 4 wires, all of them didnt work, if you could somehow tell me which wire it is, you would be my new personal hero, lol.
ps- the speed sensor wire is on connector A (the very top plug) correct?
thanks for all your help.
Jaryn
May 17, 2016 02:52 AM
