Fuel Pump Booster?
Old Oct 3, 2003
gotti's Avatar
Fuel Pump Booster?
I found this while searching ebay for a nitrous system.
Would this help some of the fuel problems you FI'ed people are facing?
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6755
To avoid running your performance engine lean, you need to "amp" up your fuel system. The best upgrade to use is the ZEX Booster Fuel Pump Kit. It is installed inline, so there is no need for the mess of dropping your fuel tank. Unlike other manufacturers who just sell you a pump, the ZEX Booster Fuel Pump Kit includes all the hoses, hose clamps, wiring, etc. you need for an easy and clean install. The kit provides the potential to boost your fuel system flow capacity up to 650 hp, even on high fuel pressure turbo, supercharged, and dry nitrous system applications. So, "amp" up and ensure that you always have the fuel you need to beat your competition. This high capacity fuel pump is an inline bolt-on and it fits any high performance automotive application up to 650hp.
Old Oct 4, 2003
EnProceso's Avatar
it might help but i dunno. i dont like things that are "universal fit".
Old Oct 4, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
plain and simple.... no.
Old Oct 4, 2003
UnOrthodox9546's Avatar
UnOrthodox9546 is an unknown quantity at this point
Why not?
Old Oct 4, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
for what reason do u need it? explain...??
ok even if ur suplying more fuel.. right... what u think the stock injectors are gonna spray that much more?
sf's FMU is perfectly fine...
anything more then that requires new injectors and proper tuning with something like greddy e-manage.
Old Oct 4, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Same as any other inline fuel pump.
Old Oct 4, 2003
gotti's Avatar
Aight, chill. Just wanted to see if it would help anyone...
Old Oct 4, 2003
C2i0v0i1C's Avatar
SuperMODrizd
it prob costs more than a in tank one too, that is prob something they market along with their nitrous kits just to make some more money
Old Oct 8, 2003
opto_isolator's Avatar
This is essentially all SF powers "fuel kit" is - an inline fuel pump with check valve......It would work but require "tuning."
Old Oct 9, 2003
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
I think it is for a return-system only.
Old Oct 12, 2003
RiceBuRNeR's Avatar
Turbo Member
thta might help my sistuation some. My stock pump has a hard time supporting 6 injectors. If I could find a (NO) presure switch to turn it on when my fuel pressure drops below a set point.
Old Aug 6, 2011
veneet's Avatar
veneet is an unknown quantity at this point
Re: Fuel Pump Booster?
pressure booster pump water pressure problem is really a bog problem .Total home water pressure booster pump is a solution for it. It will increase the pressure and give better results so you can enjoy better shower ana big cleaning and many more.It consume less power. Its safe and easy to install and fully automatic that maximize and mainrain household water presure. Maximum pumping capacity to 26 GPM ,Maximum additional pressure 40 PSI
http://www.thehardwarecity.com/products/30...er-pump/5131313
liagreenhalgh92
Jul 21, 2015 01:31 PM
EliseKStewart
Jul 15, 2015 11:11 AM
LorenzoC0395
Jul 14, 2015 08:46 PM
mistermenphis22
Jul 13, 2015 04:43 PM
CivicsClass101
Jul 9, 2015 11:14 AM
