Negative Effects
Old Sep 30, 2003
speedracersong's Avatar
Negative Effects
i think this is one of my first posts here.
anyways..
getting a turbo is good and all but im sure there are some negative effects on the car after awhile right? i mean even if you do internals, you cant really have a rock solid engine. im asking this cause cars with stock turbos dont last forever either. so a custom turbo must be bad for it right?
Old Sep 30, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
well...im pretty sure that, from what ive heard, only running 4-5psi (minimum for the SF kit) on a daily driver is just fine. As long as you have a good boost gauge and air/fuel ratio gauge, you should be fine. I have heard of someone here running 10psi daily with stock internals.
Old Sep 30, 2003
JSWhaler's Avatar
JSWhaler is an unknown quantity at this point
a turbo puts wear and tear on engines. If done properly the engine will run fine. However, with the extra wear and tear, things are sure to go, which will start to add up in the long run. Also the extra stress on the engine will not be soo good (long run again) resulting in an engine that could lose roughly 1/3 of its life over time. Hondas are known to run for a long time with turbos and other big upgrades they will play a toll on the engine.
Old Sep 30, 2003
jwalker87's Avatar
Bodacious Member
ive heard, though, that its not uncommon for Honda's to last well over 300,000 miles...so if you lose a third, you're still going to be going strong at 200k! Thats pretty good if you ask me.
Old Sep 30, 2003
derty's Avatar
derty is an unknown quantity at this point
it will last if you take care of your vehicle and watch everything carefully, and dont just push things to the side that are a need to take care of base. -=]
Old Oct 1, 2003
andyman97's Avatar
Turbo Guru
Well, I have had my turbo on my car for about a month and a half....guess how long I've been able to drive the car? maybe two weeks. The rest of it has been down time. I am now on my 3d headgasket.....which wouldn't be so bad if I had a beater daily driver.
Engine problems really suck, especially when you are working on it by yourself with noone else who's really dealt with it before to help you diagnose it. I've got so many issues with my car right now, I don't even know where to begin.
Old Oct 1, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
How bout getting those studs.
Old Oct 1, 2003
EnProceso's Avatar
our engines cost like $600 bucks, people pay that much for their exhuasts, i'm not to worried about it. just keep up with maintence and dont go crazy with boost, you will go for as long as you own the car.
Old Oct 1, 2003
andyman97's Avatar
Turbo Guru
I called my machine guy this morning, he's going to look into it and see if he can find an extra one from a d16 just to check it for fitment....if it works, I'll give it a shot.
Old Oct 1, 2003
CarbonFly's Avatar
My thoughts exactly.
Old Oct 1, 2003
Civicly02's Avatar
seriously our engine only cost 600 dollars?
Old Oct 1, 2003
jwalker87's Avatar
Bodacious Member
doode...why dont i buy another one, stick it in my trunk, and say I have 254 horsepower? Haha jk
Old Oct 2, 2003
EnProceso's Avatar
$500-$800 yes, depends on mileage and condition
Old Oct 2, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
mine was 510 with 220 miles on it ..
Old Oct 2, 2003
C2i0v0i1C's Avatar
SuperMODrizd
if you got it from a junkyard they must have been sleeping
Old Oct 2, 2003
Green Civic's Avatar
Yes if the setup is incorrect, you will fry your engine. Ive seen a miata that was boosted and that had an incorrect turbo setup and it literally fryed the parts of the engine.
Old Oct 2, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
are u talking about me? no junkyard.. i just know where to get them.
Old Oct 2, 2003
C2i0v0i1C's Avatar
SuperMODrizd
yea so what junkyard or person sells them for 500 with 200 miles on them
Old Oct 3, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
alot of places.. your just not looking in the right place... seriously. 500 was kinda high too.. but with 220 miles on it .. i couldnt complain... plus 6 month warranty....
here
www.car-part.com
Old Oct 3, 2003
well i dont know about you guys but 500 dollars, 600 dollars, hell even 100 dollars is alot of money for me. sorry if im not baller enough to just switch out engines whenever i screw the other.
so basically im getting from this you have to install it right.
but then the sf kit proclaims that you can install it yourself in a day. soo the kit's instructions are that detailed and fool proof to not ruin your engine?
Old Oct 3, 2003
jwalker87's Avatar
Bodacious Member
the engin-ruining problem is with the use. If you buy the basic SF kit and run 10psi of boost, yeah, you'll blow your engine. You just have to be smart about it, and realize that you're asking the engine to do things it wasn't built to do.
Old Oct 3, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Yeah.... the more lean you run, the hotter the engine runs.
Old Oct 3, 2003
andyman97's Avatar
Turbo Guru
No, that is not true. One boost spike high enough w/o enough fuel can throw a rod right through the motor. A turbocharger is a major modification. Everyone seems to think, oh, turbo, yeah, that's like adding a cai. Nowhere near the same thing.
Of course, the install is not hard at all. I removed the whole setup from my car in a matter of about 2 1/2 hours. I'm sure it wouldn't take me much longer to put it back in, either. But both catalyst and I have had repeated issues with our cars. From what he's told me, the car has been running solid since he fixed it last. My car isn't even running right now, either. Now I say that my issues haven't been due to the turbo directly but I garuntee that if I hadn't put it in, my car wouldn't have overheated.
Old Oct 4, 2003
Diemos's Avatar
Diemos is an unknown quantity at this point
I think what you need to realize is that the information you find here will be inheriantly biased. You see, most people here would love to cling to the false reality that if they run daily boost of 5lbs their engine will last as long as someone without boost. The simple fact of the matter, the more horsepower your car develops the harder the engine is working, thus it won't last as long. Do you guys ever wonder why american car companies put huge engines in cars to make them fast? Those motors only rev up to about 5500 RPMs, as aposed to our 7000. Generally the reason Honda's are considered so reliable is because the people who drive them don't take them above 3,500 rpms so they barely stress the engine, thus it lasts 200,000 miles. Properly maintained any engine can last as long as any other. I've noticed a bias here in favor of import engines. In Japan they have a tax for higher displacement engines, and in many other countries they have the same thing. That is why japanese car companies make small displacement engines, its not that its a better design its just cheaper. I know I didn't want to believe it either, but its true. There is no replacement for displacement. All things being equal a larger displacement engine will create more horsepower. So to make long answer short, yes it will cause your engine to fail prematurely (and add wear to all the other components on your car) NOTE: That doesn't include stereo and so forth.
- Diemos
SimpleUser
Apr 24, 2021 02:54 AM
solarpunk70
Apr 12, 2016 11:43 AM
Raiool
Oct 1, 2015 10:42 AM
Hollywoodsnake
Sep 20, 2015 12:58 PM
EngiNERD
Aug 9, 2015 08:28 PM
