Raising Boost
Old Sep 1, 2003
UnOrthodox9546's Avatar
UnOrthodox9546 is an unknown quantity at this point
Question Raising Boost
What components do i need to buy to run moore boost safely? Also w/ these how much more boost can i run?
Old Sep 1, 2003
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
rods
pistons
sleeves
block guard
head gasket
or just drop a k20a3 in there and boost 8 or 10 psi and you'll be near 275-300hp...which is probably the better route.
Old Sep 1, 2003
if i get rods,pistons,sleeves,block gaurd and head gasket, how much boost will i be able to run? Also and any suggestions on what brand of those things i should get?
Old Sep 1, 2003
Your Parts Guy
Talk to the companies you buy these products from to see what they can handle.
Rods - Crower
Pistons - JE, Arias etc...
Sleeves - Darton (prob custom app)
Head gasket - KMS has one
Block Guard - not sure search its been brought up before
Old Sep 1, 2003
Thx for the help. Also does anyone know how much boost i will be able to run safely daily w/ all of these?
Old Sep 1, 2003
C2i0v0i1C's Avatar
SuperMODrizd
whatever u want as long as u have the fuel to supply it with. also if u sleeve it, what would be the point of a block guard, in my opinion NOT AT ALL
Old Sep 1, 2003
01WingsWestCivic's Avatar
7thgen Man-gina
01WingsWestCivic is an unknown quantity at this point
kms also has a block guard
Old Sep 1, 2003
EnProceso's Avatar
what would be the first thing to replace so you can a little more boost safely? like if running 8 psi daily is safe, if you were to run 9-10, what would be first thing to wear out or break?....or would pretty much everything go out in one big bang?
Old Sep 1, 2003
Your Parts Guy
tru but if he doesnt want to go that route (sleeves) he should get one.
Old Sep 1, 2003
Your Parts Guy
I think Catalyst needed to replace his head gasket when it happened to him.
Old Sep 1, 2003
PlatCruiser's Avatar
PlatCruiser is an unknown quantity at this point
Everyone always leaves out more fuel.
Doesn't matter if you do all those upgrades to the block if you don't have more fuel you'll blow the motor.
Old Sep 1, 2003
andyman97's Avatar
Turbo Guru
First thing.....just because you want more boost, you don't need a new headgasket. Catalysts blew not because he ran too much boost but because his engine overheated....mine did the same thing. I would keep an oem headgasket, that way, with a built motor when I have problems, that's the first thing to go before I do any serious damage. Kind of like having a weak link.
As far as sleeving goes, check out this link...http://www.goldeneaglemfg.com/sleeves.htm. When you sleeve the block, there's no need for a block guard.
I agree with platcruiser 100% about having more fuel, it's a must. The way I'm planning to go once I build my motor is converting to return style, this way I can regulate fuel pressure better and get my system tuned for more boost. Also, you'll probably want bigger injectors and an fpr for return fuel system.
Tranny, your stock clutch isn't going to last long on 10+ psi of boost. You'll need a new one sooner or later.
Axles. Again, it won't be long before it snaps. If you're pushing that much hp to the wheels, you'll need an axle rated to handle it.
While you're at it, having work done to the head is a great idea. Port and polish along with new cam and cam gear and valves will help out greatly.
Old Sep 2, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
lol, i blew my head gasket at 4 psi. Usually it isnt the boost that breaks stuff, it is stupidity.
Old Sep 2, 2003
How do you convert to a return style system?
Old Sep 2, 2003
block off the stock regulator.
Add the new regulator.
Drill the tank for the return line
Add necessary lines and fittings.
Old Sep 2, 2003
I cant find any pistons that fit our cars. does anyone know where i can find some?
Old Sep 2, 2003
C2i0v0i1C's Avatar
SuperMODrizd
je makes some bc i have some, and someplace called weisco makes some
Old Sep 3, 2003
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
how much were your je's?
Old Sep 3, 2003
C2i0v0i1C's Avatar
SuperMODrizd
550
it was a custom order of course and i had to send them a stock sample
Old Sep 3, 2003
MadWheel's Avatar
Premium Boosted Member
turbo discounters sells pistons too.
Old Sep 4, 2003
If i got the turbo discounters 8.5:1 pistons, how much boost could i run?
Old Sep 4, 2003
cdmx's Avatar
There's a guy here in charlotte who built his motor with all that stuff and mabye more (not sure) but he said it was good for 15psi
Old Sep 4, 2003
so if i get all that stuff i can run 15 psi daily?
Old Sep 7, 2003
EnProceso's Avatar
i dont know about that much but with the 8.5:1 pistons, stronger rods, and gasket i think you could run 10-12 psi daily safely, any more than that i think you would need a way to feed in more fuel.
edit- thats assuming your not at WOT the whole time
Old Sep 7, 2003
Jodster's Avatar
Post Whore General
Just wait for SF to sell the different stage kits.
Old Sep 7, 2003
detoX's Avatar
detoX is an unknown quantity at this point
550
how about the rods? how much are they and the brand?
Old Sep 8, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
550..... JE ....
bowie
Jan 21, 2018 09:29 PM
C-Hamm
Sep 28, 2015 10:31 PM
Sep 27, 2015 11:33 AM
Michelle2006
Sep 19, 2015 06:09 AM
99BoostedSi
Sep 7, 2015 04:49 PM
