stock fuel pump
Old Aug 4, 2003
HondaCivicJosh's Avatar
HondaCivicJosh is an unknown quantity at this point
stock fuel pump
hey sorry for all the questions but i just want to make
sure i understand everything before i start the install this
weeken. Is the stock fuel pump good enough or should i
upgrade and do i need a presure regulator?
thanks
sorry agian
Old Aug 4, 2003
andyman97's Avatar
Turbo Guru
You actually have a few options.
1. Upgrade injectors and run safc...although I have heard that this can cause a rough idle.
2. SF Power has a Vortech FMU which will add 10 lbs fuel pressure per lb of boost you run (obviously the best choice.) I am running it with the safc for even better fuel management.
3. Additional injectors which spray directly into the throttle body with an additional management unit for those injectors which maxrev sells.
The choice is yours but I think the modded vortech fmu with the safc, although probably the most expensive, is the smartest, best controlled way to go.
CarStuff
Dec 6, 2020 12:52 PM
Jonnie.
Jan 13, 2019 11:21 AM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
