New Pistons?
Old Jul 7, 2003
salokod's Avatar
salokod is an unknown quantity at this point
New Pistons?
Do we need new pistons when we get a turbo? Also, what's the best gains outta a turbo made for our cars? this may sound stupid, and the safest?!
Old Jul 7, 2003
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
according to catalyst, he got his LX to 166 whp with his turbo boosting at about 5-6 psi... Safe is not to go beyond 8 psi...if you want to go over that, you'd need new pistons and upgraded internals.
Old Jul 7, 2003
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
WRONG! Cat has run over 10 psi safely. YOU JSUT HAVE TO PREVENT DETONATION( as catalyst does)
Old Jul 8, 2003
§C§H§O§C§O§B§O
mah bad...wasn't updated enuf
Old Jul 8, 2003
halocivic's Avatar
halocivic is an unknown quantity at this point
how do you prevent detonation? and what is it?
Old Jul 11, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
Detonation is when the fuel explodes inside of the cylinder, instead of burning. When the fuel detonates, it burns un-controllably, causing the piston to jolt from side to side. It can also cause head gaskets to blow, ring lands to crack, pistons to crack, cylinder walls to blow, and rods to bend.
You can prevent detonation by many methods....
The most common is higher octane gas. The higher the octane, the more controlled the burning is inside the engine.
You can also use water/alcohol injection. The alcohol actually increases the octane of the fuel.
You can run an intercooler, which cools down air temps, causing the engine to make more power with less cylinder pressure.
You can retard the ignition timing, which allows the burn to escape faster, before it has the chance to detonate.
There are even more ways, but they are to numerous to list.
I was running 15 psi without any detonation, and i am running 9 psi daily right now. It is all in the tuning.
Old Jul 11, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
^^so we can get this as an option on the sf kit right?
Old Jul 11, 2003
Catalyst's Avatar
there is an upgrade you can get. It is the alcohol/water injection that is on my canr and yourinmyw0rlds car.
naokigoffi
Aug 30, 2015 06:19 PM
totravska
Aug 30, 2015 12:02 AM
MamaBear2015
Aug 22, 2015 05:27 PM
Butterfli13
Aug 12, 2015 11:04 PM
Grey
30
Nov 16, 2002 12:59 AM
