Crower cams no longer available.
Old Mar 12, 2018
glamabilly's Avatar
glamabilly is an unknown quantity at this point
So I'm half way through this engine build, and today I went to Crower website to order a stage 1 cam and found out that they have been discontinued. They say they can regrind my existing cam but they can't give me numbers of what they will be able to do with it until they get mine in their hands to measure it.
-So my question today, is who else besides Crower still makes a stage 1 cam for a D17a, D17a2?
-How does this forum feel about regrinding cams?
-If I can not find one anywhere, does anyone know of a used or new one anywhere that is for sale? Summit still has it on their site, but I'm not sure they have them in stock.
thanks.
Old Mar 12, 2018
Slumpertcivic's Avatar
Re: Crower cams no longer available.
Guess somebody forgot to backup the CNC file and **** wiped out the computer.
Old Mar 12, 2018
nsrhonda89's Avatar
nsrhonda89 has a spectacular aura aboutnsrhonda89 has a spectacular aura about
You can check these guys below. I got mine from them in 2014.
chris@cnc-motorsports.com
https://www.cnc-motorsports.com/crow...-camshaft.html
http://www.jegs.com/i/Crower/258/63461/10002/-1
Old Mar 12, 2018
oooouch, the cam is great, sad to see it go
Old Mar 14, 2018
piano55man's Avatar
piano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of light
Nooooooooo!!!!!!!!
Old Mar 14, 2018
Originally Posted by piano55man
Nooooooooo!!!!!!!!
Lol, you already got one tho
Old Mar 14, 2018
mac25's Avatar
Dr Krieger of Modification
Skunk2 lists a few for the d15 and d16, you could research if the d17 takes the same camshaft.
Old Mar 15, 2018
piano55man's Avatar
but i don't have the big stage 3 yet.
I was planning on putting this in during the summer months.
Old Mar 15, 2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
thanks.
i personally have never liked the regrind idea because there's too much room for error. it's easier to keep the geometry right without having to make up .020 or .040 or whatever ends up being removed. i have a friend that is much smarter than myself and he loves regrinds. has been developing cams for eons and has crower regrind oem cams to his specs all the time. recently (about a year ago) he had one regrind for a mopar 2.4 where the base circle was cut too small and the lash adjusters could not extend far enough to have proper lash. only in one case though, all the other cams cut and sold with the same specs were fine. he ended up getting bad mouthed, had people blaming the cam he designed, etc, because the guy at the grinder made a simple mistake and took too much off the base to safely hit his specs. this is likely why they want to see and measure your cam first. i would call crower and see how confident they feel about regrinding it.
this is the actual regrind in question, and below it stock cams. you can see how much smaller the base circle becomes. if they need to grind it too small to get it where you want it.... well they'll know better than us how far they can cut without making the valvetrain geometry fubar.
^^ mopar 2.4/turbo PT
Old Mar 15, 2018
well, our cars do not have spacers, so not sure a regrind would work...
Old Mar 15, 2018
http://www.dezod.com/crower/crower-i...i-2162628.aspx
might wanna call and see if they have them in stock. Stage 2, not 3, but still. Worth a shot
edit: here's a stage 3. Recommendation to call still applies.
https://www.horsepowerfreaks.com/cro...151786177.html
Old Mar 15, 2018
For you crazy cats that wanna get custom grinds done, here's the specs for crower's D17A2 cams (had to google fu the crap out of this)
All else fails, you can order a custom ground cam to the stage 3 specs from crower. lol
Old Mar 17, 2018
glamabilly's Avatar
So with a regrind, I'm guessing all the material is taken from the back side of the lobe. Do you think the same lift and duration can be achieved? Also if I have to get a custome grind, would it be better to change the values and get a cam someplace between the stage 1 and 2? I want to keep the stock valve springs and retainers for now, because I think they have discontinued them as well. Are valve springs and retainers for other D series engines compatable with the D17A2?
Old Mar 17, 2018
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
I'm glad I bought one when I did. But you could get one here if you act fast: https://www.ebay.com/i/123020513845?chn=ps&dispItem=1
Old Mar 20, 2018
RobertD's Avatar
they will grind the minimum amount necessary off the lobes before regrinding just to clean things up, and may grind off the tip of the lobe if the new profile has lobes shaped more like the butt of an egg vs the tip of the egg, as it's the only way really add duration without getting nuts with lift.
Old Apr 15, 2018
glamabilly's Avatar
Thanks for the info, I’m going to send in the cam to crower and see what they can do. It’s $180 for a regrid, that’s about half of the cost of a new one.
Old Apr 16, 2018
piano55man's Avatar
Wait, you can send in the stock cam and they will make the stage 1,2,or 3 cam???
Old Apr 16, 2018
Darn. I wish I knew that before I spent $400 on a stage 1 cam. I thought by “regrind”, they just meant polishing the lobes smooth again if they were scored. I didn’t think that they could add material.
Old Apr 16, 2018
RobertD's Avatar
they do not add material, they remove it from the sides and bottom, which makes the base smaller and the lobes act taller/wider/etc.
depending how much is removed, you can run into unforeseen issues: lash adjusters no longer centered on the valve stem causing valve guides to wear or valve tips to mushroom, rollers lower causing the pressure to exert more sideways than vertical, etc.. which is why they will always want the cam in hand to measure before deciding if there's enough meat on it to do what you want.
pic is just a BS pic i made where the center was made smaller so you can see how i illustrated it making the lobe 1/3 taller
Old Apr 16, 2018
glamabilly's Avatar
They can’t add material, from my conversation with them, they can make the back and sides of the lobe a bit smaller, after the lifter is adjusted to take up the difference, it will act like a larger lobe. They have no information to give me on how much they can change it, they will have to measure it first and get back to me with the values that they can get. Things like ramp angle lift and duration will be as good as they can get, they can’t guarantee a stage one or two profile. It may only end up not even a stage one. I’ll keep people posted with the values they come up with.
Old Apr 16, 2018
I see, thanks for clarifying.
Old Aug 22, 2018
glamabilly's Avatar
So I finally got the numbers back from Crower. They can regrind a stock d17a2 cam. The OEM numbers are 183 degrees intake and 171 degrees exhaust with .199 and .163 of lift respectively. The maximum numbers they can get me are .188 degrees intake and .180 degrees exhaust, with .213 and .175" of lift.
For comparison the stage one cam they used to offer was 188 degrees intake and 180 exhaust with a .217 and .190 lift with 188 and 180 degrees of duration. The turbo cam had .237 intake lift and .218 exhaust lift with 193 and 183 degrees of duration. The turbo cam requires the spring and retainer kit they sell.
Anyone have a opinion on those numbers?
Old Aug 22, 2018
piano55man's Avatar
If you want to retain your stock setup, i would go with the stage 1 grind.
If you decide to go bigger than the stage 1 specs, you better have some sort of programmable ECU.
I personally thru in a stage 1 this spring and went ahead and upgraded the springs and retainers, because i knew i would be going with a bigger cam in the near future.
I'm curious if i can get a stage 3 grind from the stage 1 cam????
Old Aug 22, 2018
RobertD's Avatar
The max numbers they can get are 188 degrees intake and 180 degrees exhaust, with .213 and .175" of lift.
For comparison the stage one was 188 degrees intake and 180 degrees exhaust with a .217 and .190 lift
instead of losing shipping money you might have them cut it, try it. the stage 1 duration is there, you may love it.
if you decide if you want something bigger, you'll at least have something worth some $$ to sell. i imagine in an ad that would be found by someone seeking a stage 1, your cam would resell pretty quickly and would cover anything you spend on the shipping, grinding, vc gasket, etc
i never realized how tiny honda cams are. mine's In:222 / Ex:230 with .512/.512 lift, which is on the small side for a v8.
Old Aug 22, 2018
piano55man's Avatar
I have a Crower stage 1 cam in my "power house" now.
All this talk of regrinds got me wondering if Crower can get the stage 3 grind from their own stage 1....
I plan on calling them in the future to find out.
a bit off topic, but does anyone have a d16 cam laying around that they would be interested in giving away minus shipping?
i'm curious how different the cams are.
Old Aug 22, 2018
RobertD's Avatar
this is how much that 0.015 missing EXH lift is, the Intake lift missing is 1/3 or that. i doubt you or the engine would notice the missing lift.
Old Aug 22, 2018
piano55man's Avatar
that's only double the exhaust lash thickness....
Old Aug 22, 2018
glamabilly's Avatar
This build is taking me a while, I’m not sure how long it will take now that they have the numbers, but I hope to get it back soon. I’ll post something on this thread when I get it in the car. Having said all of that, it does look like you could just go to a junkyard, get a cam for almost nothing send it in to have a regrind, all for almost half of what the stage 1 cam would be, and it is only off by just a few thousands of an inch. This is really just an experiment for me, if I get some good results, it is going in my rally car. Just a few hp extra might make all the difference over a rally stage, and if it looks OEM maybe no one will notice.
Old Aug 24, 2018
piano55man's Avatar
just remember...your never cheating unless you get caught...
Old Aug 24, 2018
I think the proper quote is "it's only cheating if you get caught" lol
