auto tranny to 5speed tranny swap
Rep Power: 0 i was going to do the swap as well but i dont think it's worth it, search around like i did theres some threads that tell you everything you need and what you need to do for it their just hidden somewhere if i find em ill give em to ya
Rep Power: 0 elite was the 7htgen member to first do this swap i think it cost's around 1200 in parts maybe more but its deff under 2g's labor included do a search for transmission swap started by elite
Edit: here you go http://www.7thgencivic.com/forums/sh...d.php?t=123114
K20 Member
Rep Power: 0 on the EX the hole is there.... here is everything you need. I was going to do it and then decided against that idea.
Tranny
Tranny Mounts
ECU
Shift Linkage
Shifter Assembly
Subframe
Dash wire harness
engine wire harness
Starter
Slave Cylinder
Clutch master cylinder
clutch
flywheel
pedal assembly
Axels
and thats it i think or at least thats all i can remember off the top of my head.
Tranny
Tranny Mounts
ECU
Shift Linkage
Shifter Assembly
Subframe
Dash wire harness
engine wire harness
Starter
Slave Cylinder
clutch
flywheel
pedal assembly
Axels
Rep Power: 0 yeah i'm still think about whether or not to do it i thought it could be done for like 600 because i can install myself but i dont want to waste a grand on it unless everyone would think it gives you that much of an upper hand
BOOSTED DOHC i-VTEC
Rep Power: 0 would not recommand Honda to the swap (I am not too sure if they do it anyway). their installion prices will kill you. check ur local shop and ask for prices.
begogadashi
06-11-2015 04:04 AM
MajTom
06-02-2015 11:48 AM
