installing front top grill
Old May 4, 2005
redspeed03's Avatar
redspeed03 is an unknown quantity at this point
how do you install a new top grill? Just want to know before i do it and try figuring it out
Old May 4, 2005
Diver's Avatar
Diver is on a distinguished road
goto grillecraft.com
they have a great DIY for our car that applies to all grille
Old May 4, 2005
civicvtec1ps's Avatar
Search and Learn
Take front bumper off and put it on.
They are just held by clips and screws.
Easy.
Old May 4, 2005
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
its held to the bumper twoard the top of the bumper and lower part of the grill by like 4 clips
Old May 6, 2005
Octane Joe's Avatar
it is held by 4 screws, one in each fenderwell, and two underneath, their are I beleve 8 clips if I remember correctly, 2 bigger ones at the ends of the bumper underneath and dont forget the 2 upper ones under the hood... make shure to get a friend to help or put a piece of cardboard down so you dont scratch the bumper. Once you get all the clips/screws off... go to one of the headlights and pull toward you on the bumper by gripping it in the wheel well, it should pop right off toward you... the bumper is held in by alot of clips inside the bumper (not the kind you have to remove, so dont worry, it just slides in and out of these clips) then when you have one side loose, go to the other and pull it off, it should just fall down (this is why you need cardboard/friend) if you have any more questions, I have taken my bumper off way to many times (DIY cleared headlights, then i later blacked them out, then I resealed them, installed a new horn, altezza grill 2 times) so I should be able to help you out... good luck
EDIT: here is the link to the DIY for clearing your headlights, it has a good bumper removal inforation w/ pics DIY
1.7ali
Sep 6, 2015 07:36 AM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
usajags84
15
Aug 19, 2015 03:12 AM
ScottyEj8_DB7
Apr 26, 2015 04:07 PM
