**Pictures of Rear Disc Conversion**
Saw on another post that you had to get some sort of proportioning valve to make the conversion actually work, as in distributing the brake force evenly. Did you do the same for your conversion?
Supercharged k20a3
i just put the brakes on my car without changing the poprotining valve or the master cylinder, and the brakes work fine i need to do some brake tests but you don't need to buy that other crap. and you havto get the nucle hub caliper brake lines and ebrake cable to convert it you can't just get rotors. but if and when i get new rotor i will get sloted not driled, and they usualy run $90 for each rotor, and like $50 for a set of pads.
Initial D!!!!
Originally posted by Drivetofast
i had to replace all the brake stuff and the knucle, pluss the ebrake cables. i will do it for you , parts and labor $600
ill have to call you up in the next few months then.
Escaped Convict
blanks works better than slotted or cross drilled or both.
those tends to crack easier... and IMO they're more show factor than the "cooling down rotor" factor.
IMO we dont really need rear disc for a stock civic.... sure it stops better... but on a FWD vehicle... I believe 90% of the stopping is done on the front.
but yeah the rear drums sure looks silly and pitiful when you got rims.
Honda's really cheap on the brakes... the civic should have four wheel disc brake... and most of the models should have ABS available...
bah.
bah.
--< GripSpeed Member >--
with the extra brakin power... and not having workin done on the proportioning valve...does ur car seem like its goin to lock...when u brake hard and suddenly
Supercharged k20a3
with any stock or aftermarket brakes it will lock up if you brake all of a sudin or top hard enles you have ABS but i have sticky tires so i can take advantige of the better braking
Supercharged k20a3
i do work for a dealership but i go them used from a really good reking yard. and if you really want it done to your car i will do it for $700 instaled.
Supercharged k20a3
DestnationUnkwn your a dork don't talk trash on my thred, i can charge whatever i want and $700 is a really good price and when i said $600 that was like almost nothing over the cost of parts
Originally posted by Isaiah1975
how much would it be for just parts?
h4ldol
Apr 24, 2017 08:16 PM
Sep 27, 2015 11:33 AM
hatch90
Sep 3, 2015 08:45 AM
