Need help really bad? (solved...check it out)
Old Dec 23, 2002
iceman's Avatar
--< GripSpeed Member >--
Hey wassup...right now i am rollin on 215/45/zr17 tires on a 2in drop all the way around...and my camber is all off..so i took it to a shop today and had them correct it...BUT...they said that i would need to shave or roll my fender so that they could correct the camber...i;ve checked out a couple places and they said they were goin to charge me bout 60 bucks a side...so bout 120 total...and then an additional 95.00 for camber correction...and 45 for the 4 wheel alignment..just curious if anyone knew any places that would shave or roll the fender for a cheaper price...thanx
Old Dec 23, 2002
spoiledsteph
Guest
Posts: n/a
thats some BS right there...you don't need to roll your fenders to stop gettin negative camber. you need to buy a camber kit. i got some 215/45/17 too, and my ish is fine, well i got negative camber, but i just got a kit from hondawerx for 140 shipped. a full kit. you don't need to roll your fenders unless you want to.
Old Dec 23, 2002
iceman's Avatar
hey wassup steph...i have the camber kit installed...but i need to correct the camber...so that i wont have a negative camber...in order to do that...the shop said that i would have to roll my fender...so that the tire would sit straight wit out rubbin against the fender
Old Dec 23, 2002
Erichyung's Avatar
Erichyung is an unknown quantity at this point
$30 is a reasonable price for cutting fenders.
Old Dec 23, 2002
VNlilMAN's Avatar
The Standard One
ya 215-45-17s are some pretty thick tires.. its about the size of my 18s and i know if i wanted a camber within spec i would have to roll them too.. i would just do it myself.. use the bat trick... jack up the car, stick a bat between the tire and fender and start rolling... people say it can crack the paint but i dont think it would... i'm sure the shop doesnt do anything to prevent the paint from cracking either... if you want specific instructions, just ask here..
Old Dec 23, 2002
iceman's Avatar
hey wassup everyone...my problem is solved...well hopefully found a shop that gave me the best deal...120.00 for rollin the fender....correctin camber...and a 4 wheel alignment...hopefully they do a good job...if they do ill give u guys the info on the shop...so that u can get the same deal...wish me luck..that they do a good job
Old Dec 23, 2002
spoiledsteph
Guest
Posts: n/a
mine don't rub or hit the fender.....thats the first that i heard that you need to roll the fenders to correct negative camber
Old Dec 23, 2002
iceman's Avatar
one of the main reason why i need it is because i have a no finger gap..so its really close to rubbin...the way it is..wit the negative camber..once they straighten the tire..its gonna shredd the tire up
SimpleUser
Apr 24, 2021 02:54 AM
Green02civic
Jul 27, 2015 10:48 PM
cukaracha
30
Jul 26, 2015 12:01 PM
CivicsClass101
Jul 9, 2015 11:14 AM
Bounddyy
Jul 8, 2015 11:22 AM
